Could this be a fuse problem?
Now the cig lighter doesnt work, and more importanly the lights on the radio and temp/AC are both lit like its at night. Also the MPH blue light is not lit. The Twilight is turned off, and when I turn the lights on the MPH then lights up but the light for the radio and Temp both look like its at night. During the day you really can see it at all.
This is a 2000 Manual C5.
Ok I replaced the Fuse and now the Cig lighter works, but I still have the problem with the display lights not showing up bright for the day and th MPH still does not display. When I turn the lights on then the MPH displays. I forgot to mention before. I put in a bulb while I had the speedo out. There was not a bulb for the Airbag so I bought one $8.00 a bulb. I bought 4, so if anyone needs some let me know. But anyway I installed a bulb in the spot where there was not one. Could that do it?
Anyone know what I should look for?
David
Someone suould put this in the notes somewhere so it will save someone a lot of greef!
