B0361 code, 99hvac
Old Apr 27, 2006 | 12:07 AM
mmorse's Avatar
mmorse
Default B0361 code, 99hvac
Any idea what this code is and how do I prevent it?
thanks
Old Apr 27, 2006 | 09:53 AM
bobc997615's Avatar
bobc997615
99-HVAC - Heater, Ventilation, Air Conditioning
B0332 Outside Air Temp Sensor Short to GND
B0333 Outside Air Temp Sensor Open
B0337 Inside Air Temp Sensor Short to GND
B0338 Inside Air Temp Sensor Open
B0348 Sunload Temperature Sensor Open
B0361 Left Actuator Feedback Short to GND
B0363 Left Actuator Feedback Open
B0365 Right Actuator Feedback Short to GND
B0367 Right Actuator Feedback Open
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
B1016 Loss of Communications with PCM
U1064 Loss of Communications with BCM
U1096 Loss of Communications with IPC
U1255 Serial Data Line Malfunction
Clear code from DIC panel & see if it resets the code.
