wires thru firewall?
Old Apr 28, 2006 | 03:31 PM
billiardcue's Avatar
billiardcue
Default wires thru firewall?
How do you get wires for auxiliary hook-ups through the firewall into the cabin?
Old Apr 28, 2006 | 07:11 PM
MattB's Avatar
MattB
Check out the audio section. I saw some guys there saying that they were able to push a large wire through the opening between the battery and the fire wall, its a little lower than the battery and has a rubber fitting around it. I couldn't get one though myself though. Maybe I didn't use a heavy enough gauge wire.
Old Apr 28, 2006 | 08:47 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
There's a grommet behind the battery you can go through. You can also come through where the hood cables go through. There is also room in this area to drill a hole and install a grommet near the hood cable area.
To wires thru firewall?
