AC Drain Tube
Old Apr 28, 2006 | 08:52 PM
BELVIN20's Avatar
BELVIN20
Default AC Drain Tube
I have seen a lot of questions on the A/C Drain lately. Last year I cleaned my drain with a short wire and all was well. The big question, can I take an air hose with low pressure and blow up the drain hose to make sure it is clear. The utter is so small that I am thinking of cutting the end off to make sure it does not stop up again. Thoughts?
Old Apr 29, 2006 | 08:41 AM
cliff_ford's Avatar
cliff_ford
The best thing to do is to put a vac. on it and suck out the blockage. That's what I did and I got out a small slime mould pellet.
Old Apr 29, 2006 | 08:52 AM
Oldvetter's Avatar
Oldvetter
Just blowing debris into system only prolongs problem.
Old Apr 29, 2006 | 09:28 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
I found a piece of plastic hose that fit over the A/C drain hose and then duct taped it to a vacuum hose. Sucked out a bunch of stuff and have had no trouble since. You'll have to reach down and work the drain hose around so you can get a vacuum hose on it, but simply blowing air in to it aint gonna help...JMHO.
Old Apr 29, 2006 | 08:25 PM
htvette's Avatar
htvette
Where is the AC drain hose located? Thanks
Old Apr 29, 2006 | 10:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here ya go!!!!!!!!!
The drain tube is on the passengers side of the fire wall. The flash light is shining on the area where it is located. Its best to reach it from under the car. If you have headers, get it from the TOP!!!
Is on the fire wall where the light is shining. Look in the recessed area highlighted by the light!
BC
Old Jul 15, 2006 | 09:23 AM
ytwokc5's Avatar
ytwokc5
Had the A/C leak into the passenger footwell problem yesterday. Pulled the carpet back to let everything dry.
I yanked the drain hose this morning and sure enough it was clogged with a slimeball. My question... how do I get the drain hose back on! Do I install from on top or do I have to get underneath the car? I'm pulled it from the top, but I'll be damned if I can figure out how to get it back on.
Since the leak my Security light comes on whenever I start the car and does NOT go out. I unhooked battery last night and rehooked it this morning... no change. I tried to pull the ECM to make sure it was dry... how the heck to I unhook the three wire bundles connected to the left side??!?! Any and all help is appreciated.
Old Jul 15, 2006 | 11:35 AM
mayberry's Avatar
mayberry
All three bundles have a clip that you need to depress to pull them out. They can be a bit hard to remove but as long as you are pressing the clip, you can get them out. Take it out and make sure it is dry. I just got done replacing mine due to it getting wet and fried. PM Bill Curlee, he was of great assistance with troubleshooting mine. Good luck!
Old Jul 15, 2006 | 12:50 PM
ytwokc5's Avatar
ytwokc5
Thanks... any tips for re-installing the A/C drain tube that comes out of the firewall? Can I run the A/C without the tube?
Old Jul 15, 2006 | 02:19 PM
LS6WeekendWarrior's Avatar
LS6WeekendWarrior
Default a/c drain line...
My problem is different, in that it is draining fine, but it is draining cold water onto my SS headers, and sizzling on there until the headers cool down. Aside from the annoyance of the dripping, sizzling sound, I'm wondering if the hot metal meeting the cold water will eventually crack the steel? Anyone else experiencing this?
Old Jul 15, 2006 | 02:49 PM
mayberry's Avatar
mayberry
I was finally able to reinstall it from under the car. It took some time and cussing, but finally got it back in. Not sure about running it without the tube.
Old Jul 15, 2006 | 04:47 PM
LoneStarFRC's Avatar
LoneStarFRC
Sounds like you're working on the BCM, (Body Control Module), not the PCM. You're definitely checking the right things.
HTH,
Robert
BTW, I would keep the hose and just snip off a little of the rubber to make the opening larger.
Old Jul 15, 2006 | 06:40 PM
ytwokc5's Avatar
ytwokc5
HTH,
Robert
Thanks for the feedback everyone... def the BCM LoneStar. Good news is I dried everything out really well, no more "Security" light staying lit and no other error codes. Ran through the error codes in DIC and all were History codes. Carpet and backing dried out really well. The one remaining item is to reinstall the drain hose, def plan to snip off the narrow opening.
Old Jul 16, 2006 | 12:57 AM
ALLEGRO's Avatar
ALLEGRO
Can I get to the tube without raising the car?
I don't have moisture in the car, just a bad smell when I get in the car the next day. If I remember to turn off the compressor the last mile or so of my ride, it doesn't smell the next day.
How do I get to it to check?
Old Jul 16, 2006 | 03:04 AM
c5mtl's Avatar
c5mtl
same problem for me
Old Jul 16, 2006 | 08:09 AM
GreenHornet1's Avatar
GreenHornet1
Same here, well actually it drips down onto my stock manifolds...
Old Jul 16, 2006 | 09:05 AM
YO-EL's Avatar
YO-EL
No problem, the headers are so hot, the drops of water just boil off...
No damage to them..
Old Jul 16, 2006 | 10:46 AM
zreddog's Avatar
zreddog
St. Jude Donor '11
what a great feature! For those of us who live where humidity is rampant.
after a few hours of driving around Yesterday my friend started complaining about his feet being wet.
Pulled the hose and at least 8oz of water came pouring out
Yep! it had some white sludge in it.
I figure the hose is designed to keep dirt out so I am not in a hurry to replace, but the next time its on a lift I will have it re-attached.
Old Jul 16, 2006 | 10:48 AM
zreddog's Avatar
zreddog
St. Jude Donor '11
BTW - BIG thanks to Bill for the pictures! that really helped me out.
To AC Drain Tube
