*** Urgent!. Need Z06 alignment specs!
I’m getting alignment done tomorrow morning and I need Z06 specs.
Thanks a bunch in advance!!!! :yesnod:
These are the official Z-06 4 wheel alignment specifications for the Z-06. There were sent to me from Sonny Kilgo at Bowling Green, and confirmed by Mike Neal, a ride and handling engineer on the Z-06. I hope this solves any problems that my arise. The alignment numbers are different than the coupe/convertible.
This is specific to the FE4 suspension.
All numbers are in degrees.
Front ind. caster-as shipped- +6.7 +/- .5
-curb- +6.9 +/- .5
-design +7.3 +/- .5
Front cross caster-as shipped- within +/- .25
- curb- within +/- .25
Front ind. camber-as shipped- -.70 +/- .5
- curb- -.70 +/- .5
-design- -.75 +/- .5
Front cross camber-as shipped-within +/- .25
-curb- within +/- .25
Rear ind. camber- as shipped- -.64 +/- .5
-curb- -.68 +/- .5
- design- -.75 +/- .5
Rear cross camber- as shipped- within +/- .5
- curb- within +/- .5
-design- within +/- .5
A question I have is why you want Z06 specs? In your signature, you post your stats for the strip so I assume you're a drag race fan. I think you would be better advised to set your tires up straight with the strip for better traction, less irregular tire wear, and less rolling resistance if you want to do all you can to cut down the et's.
Just my $0.02 worth.
Just to clarify I have Z51 suspension and 18x9.5 front, 18x10.5 rear rims with BFG G-Force KD 265/35/18 front, 295/35/18 rear tires and Blistien shocks.
So it’s pretty much a Z06setup (99% of it anyway), that’s why I want Z06 aligment…
alanh, my posts might’ve been confusing, but I’m actually a huge handling fan. I always wanted a road race setup. I very much enjoy taking corners and on ramps at insane speeds.
I go to the drag strip just to get a measurement of my street straight line performance (how bad I’ll be kicking peoples a s s on the street ;)
) It’s also a good practice and it’s a lot of fun :D, but I don’t really care about racing other cars at the strip (C5 is the last car I’d chose just for that)Thanks again, guys!!! :seeya
[Modified by EuG, 11:13 PM 8/21/2001]
Just to clarify I have Z51 suspension and BFG G-Force KD 265/35/18 front 295/35/18 rear tires and Blistien shocks.
[Modified by EuG, 11:06 PM 8/21/2001]
