Seat movement on the rails?
Old Apr 29, 2006 | 10:47 PM
ruf455's Avatar
ruf455
Default Seat movement on the rails?
Does anyone know if there's an easy or inexpensive fix? My sport seats will move forward a few millimeters on a hard stop, or just if you rock the seat, it will move back and forth. Anyone else have this problem or know how to fix it INEXPENSIVELY?
Thanks.
Old Apr 29, 2006 | 11:04 PM
DeeGee's Avatar
DeeGee
Here ya go:
https://www.corvetteforum.com/techti...=251&TopicID=1
Old Apr 30, 2006 | 04:19 PM
mrtoner's Avatar
mrtoner
-first remove the seat from the car by removing the 2 front bolts , then move the power seat forward enough to reach the 2 back bolts , then remove them .
-disconnect power seat connector .
- remove seat from vehicle .
-on a clean surface , turn seat upside down .
- towards the front of the seat tracks , you should have 2 gear reducers , to which a spring rod with square ends is attached .
- it does not matter which side you pick , but remove the 2 small torx screws that hold it in place ( there is a plastic spacer between the reducer and the seat frame ). then remove the reducer from the screw drive only , leave the side connected to the motor alone.
- get a square bit the same size of the spring connector , insert into the screw drive end and turn in any direction to see the track travel about half to 3/4 of an inch .(an original marking would help you measure your exact travel )
-this will make your tracks uneven by about 3/4 of an inch .
- put the spring rod / reducer back in place , then re-install the 2 torx screws .
- take the seat back to the car , connect electrical connector , then slide tracks over the screws in the floor .
- it will be a tight fit now because the tracks are now uneven , but they will go in .
- tighten the bolts , and you are done !
Half hour, including getting another beer
To Seat movement on the rails?
