11.1 compression ratio and detonation
Old Apr 30, 2006 | 07:49 PM
russellnewnham's Avatar
russellnewnham
Default 11.1 compression ratio and detonation
Does anyone experience any detonation (and related timing retardation by the computer) with 11:1 comp ratios?
If so, is it only when the temp gets above 100 F.
I ask because I am just about to install AFR heads and 40 thou headgaskets on my 2001 C5 which will give 11:1 comp ratio.
I am told by several tuners in Australia, which is where I live, that this is very high for a two valve/cylinder engine and I may experience some problems with detonation. Hence, I may experience timing retardation well below peak power.
Octane rating will obviously effect this scenario. The octane rating in Aus is 98 RON, whereas it is 93 in the US (an average of the MON and the RON). I have been told that the two octane rating of the two fuels, i.e., 98 RON, and 93 (average of MON and RON) are equal,
Does anyone have any input/knowledge here please ?
I would prefer to not pull off the heads again and change back to standard head gaskets because of loss of power resulting from excessive retardation if possible.
Old Apr 30, 2006 | 08:37 PM
JR_VET's Avatar
JR_VET
I have a friend with a 2003 Zo6 with ET 215 heads 58cc with composit gasket. athe combination is pushing 12:1 CR with no detonation. Also, he hasn't experience timing retardation above or below peak power. also made great RWHP/TQ.
Old Apr 30, 2006 | 09:03 PM
Monks's Avatar
Monks
My motor with FFHP 59cc heads and forged pistons is 11.47:1 CR.
No problems on pump gas at all ( 93 octane)
Russ
Old Apr 30, 2006 | 11:52 PM
SpeedyZ's Avatar
SpeedyZ
It will have a lot to do with your cam choice. If you have a fairly radical cam you can push higher static compression ratios before you get into trouble. I bought AFR 205 heads from LG that are cut .042 to 59cc and they swore I would not have any problems on 93 octane. I figured they have done enough to know, so I bought them! Now I just have to get the car on the road!
Old May 1, 2006 | 12:04 AM
russellnewnham
the cam is mild.
224 224 0.581 114.
It sounds like I should be okay then. Worst case is a days labour and another set of head gaskets I guess.
Old May 1, 2006 | 08:35 AM
6Speeder's Avatar
6Speeder
I'm running a milder cam (218/218, .561", 114) and higher CR: 11.4. It ran fine, no KR on 93 gas, now runs fine on 91 octane AT 5,000 ALTITUDE.
You should be OK. Modern design, fuel injected,Aluminum block/ high quench heads can run higher compression with less issues than in the past.
Old May 1, 2006 | 09:13 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
The key is Dynamic CR.
To 11.1 compression ratio and detonation
