2.5 or 3.0" X-Pipe
Old May 3, 2006 | 04:25 PM
vettrified's Avatar
vettrified
Cruising
Default 2.5 or 3.0" X-Pipe
I recently bought a 2000 vette and I'm looking to put a cat-back system on with an x-pipe. Can anyone explain the difference in performance between a 2.5 or 3" x-pipe. Also, does the difference in diameter require any additional pipes or possibly welding?
Old May 3, 2006 | 04:26 PM
2000BSME's Avatar
2000BSME
I've read in 'vette publications that a 3" almost ALWAYS makes more power. I went with the standard 2.5" due to cost.
Old May 3, 2006 | 04:38 PM
stngh8r's Avatar
stngh8r
Have you guys seen the new "X" muffler by Dynomax? kinda interesting, but i doubt it would fit anywhere in our C5 tunnel.
http://store.summitracing.com/egnsea...18531&D=318531
By the way 2000BSME- i like the avatar
Old May 3, 2006 | 04:42 PM
Blow Torch's Avatar
Blow Torch
I purchased the magnaflow 3" x-pipe and am considering installing it. I was concerned about the car being too loud (magnaflow mufflers) and possibly losing a little low end torque. Feedback has been split about down the middle.
Old May 3, 2006 | 05:25 PM
tiojames's Avatar
tiojames
Default 2.5"vs3"
If you are not doing anything else to the engine 2.5" will be fine. If you are planning of H/C package or other HP mods go with the 3". Almost all headers end in 3" pipe, so 3" hi-flo cats and entire 3" system is way to go for horsepower.
To 2.5 or 3.0" X-Pipe
