The $5 Solution......
Old May 3, 2006 | 11:43 PM
NJ Vette Guy's Avatar
NJ Vette Guy
Default The $5 Solution......
Only $2.50, if you have a friend that owns another C5/C6
I've seen ads in this forum and similar "diy" projects on other forums to eliminate water/dust collection at the rear lights. In all the solutions, it involved getting weather stripping for a door and it cost between $15 and $25, either at Lowe's or from a certain few aftermarket parts suppliers.
I decided to go the "Lowe's route" and do it myself. When I got to Lowe's, they didn't have the specified weather stripping I saw in another site's tech forum, so I looked at what else they had and this is what I found:
Frost King X-Treme Rubber Weatherseal
It wasn't the exact size or brand of the other site's "recommended" weather stripping, but it was close enough, so I tried it and I'm very happy with the results.
This particular stripping is 3/8" wide x 1/4" thick and the package contains 17' of stripping (enough to do two cars or make many mistakes ) It is a "D" profile, not the "recommended" teardrop profile, which I think makes a tighter fit. It has self stick tape and I suggest you applying the strip with one edge aligned to where the (black) lamp housing assembly meets with the (red) lamp cover.
The strip itself is a grey colored roll that is 8 1/2' long, that is actually two strips in parallel. All you have to do is tear the two strips apart from one another...... The part number on the box is: V25G
The results look like it was meant to be done that way..... If you decide to do this quick mod, good luck. It'll be the best $5 you ever spent on your Vette.
Old May 4, 2006 | 02:20 AM
MeekRN's Avatar
MeekRN
Default *
do you have a picture of you rfinished project??
Old May 4, 2006 | 03:25 AM
NJ Vette Guy
Here you go.....Here's a close up
You can barely see the grey weatherstripping around the edges. The widest gap to fill is along the bottom of the light..... Exactly the same place the water/dirt flies out of and collects at.
Old May 4, 2006 | 05:07 AM
NSTG8R's Avatar
NSTG8R
.. i've been meaning to do this.
Old May 4, 2006 | 07:55 AM
rws.1's Avatar
rws.1
I did the same thing, except put the weatherstripping a bid further toward the red lens... It looks fine on my QuickSilver Vert, but I would follow NJVette guy on other colors ( or if I did it again)
Old May 4, 2006 | 09:17 AM
99 vett babycar's Avatar
99 vett babycar
did mine about a year ago - got tired of sopping up water from the rear lights every time I wased the car. works great. never posted because I didn't know if was the "proper" thing to do since some forum vendors were selling a similar produt at a higher cost. I thought if I had figured it out on my own other people could also figure it out.
Old May 4, 2006 | 10:25 AM
rws.1's Avatar
rws.1
99 Vett babycar.... how have they held up after a year???
Mine have been on about 3 months...
Old May 4, 2006 | 11:10 AM
b98's Avatar
b98
good info.
Old May 4, 2006 | 11:32 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Great idea. I am going to do it sometime this week. It's raining here so it will be on just in time for the wash and wax.
Old May 4, 2006 | 12:15 PM
jrose7004's Avatar
jrose7004
I need to do that!
Old May 4, 2006 | 01:31 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That would be more of a reason to post it. To hell with the Corvette tax.
Old May 4, 2006 | 02:22 PM
itsmeek's Avatar
itsmeek
i honestly don't see why anyone would be ok with us getting ripped off for a vendor for a product that costs them 1/10th of what they sell to us for.
it's like paying $50k for a supercharger setup.
Old May 4, 2006 | 05:32 PM
raztek's Avatar
raztek
A different and FREE solution is to remove the lights and drill out a small hole at the lowest point of the taillight housing in the rear fascia. Only a small hole is needed. After you wash the car, the water just drains away!!! Did it to my car and have never had streaking/dust problems since.
Old May 5, 2006 | 12:07 AM
Stiffy's Avatar
Stiffy
Great tip guys....thaxs
Old May 5, 2006 | 08:17 AM
99 vett babycar
last time I looked (about 2 months ago) they looked brand new.
Old May 5, 2006 | 06:35 PM
NJ Vette Guy
That's exactly why I posted this thread. I don't mind paying money for something and trust me, I've spent some serious $$$ on this car, but so far, I feel it's worth it.
That said, if I can save myself (or a fellow Vette owner) a few bucks, you better believe it, that I'll share the info with all you fine folks!
To The $5 Solution......
