Pcm Q's
Old May 4, 2006 | 12:34 AM
griffgoody's Avatar
griffgoody
Default Pcm Q's
Has anyone ever had to change their pcm? If so, what was the symptoms for changing? I have a 98 that wont crank. Ive tried everything and changed everything that the codes suggested. Looked at the pcm and it had a lot of corrosion from the battery and salt water over the yrs. A lot of the wires has corrosion on them and some of the pins are broken off. So i'm thinking this might be the problem. Suggestions welcomed. TKS JOHN
