GM O2 sensor?
Old May 4, 2006 | 11:55 AM
fatbillybob's Avatar
fatbillybob
Default GM O2 sensor?
Hi,
I'm trying to use a bosch universal sensor as a GM replacement for their Denso unit and I need to splice in the old denso connector. That saves me 100 bucks! Problem is Wire colors are different. How do I figure out which wire is the trigger? Can I assume that the two same color wires are the heater and thus no polarity, AND if one of the other 2 wires left ground to the case of the O2 sensor then the other wire must be the trigger?
gm wires are 2 blacks , 1 white , 1 blue
universal wires are 2 white, 1 black, 1 grey
Thanks Guys
Old May 4, 2006 | 01:35 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Why the OEM replacement are the same price:
Bosch part # 13111 $59.99
Product Description: OXYGEN SENSOR - OE TYPE AFTER CATALYST
NOTE: Two Required
Bosch part # 15703 $46.99
Product Description: OXYGEN SENSOR - OE TYPE BEFORE CATALYST
NOTE: Two Required
