Help with codes...
Old Aug 22, 2001 | 04:34 PM
ZZTruck's Avatar
ZZTruck
Default Help with codes...
I got a P0480 FC Relay 1 Control Circuit code. Popped up last week. I can clear it and it will go away for a while...then come back on. It only seems to pop up right after starting and not consistently. Anyone have any ideas?
Thanks :cool:
Old Aug 22, 2001 | 05:52 PM
BruceF's Avatar
BruceF
Default Re: Help with codes... (yello2K)
This is the Fan Control Relay #1 This is the relay that controls the low speed operation of the fan.
Have you noticed if the coolant temperature is coming up more quickly? Is the fan coming on?
Do you have an aftermarket fan controller?
Old Aug 22, 2001 | 06:28 PM
ZZTruck's Avatar
ZZTruck
Default Re: Help with codes... (BruceF)
"This is the Fan Control Relay #1 This is the relay that controls the low speed operation of the fan."
"Have you noticed if the coolant temperature is coming up more quickly? Is the fan coming on?"
The fan is coming on....and no..the temp seems to be the same. I will keep a closer eye on it.
"Do you have an aftermarket fan controller?"
No..
To Help with codes...
