Intermittent turn signals?
Old May 4, 2006 | 06:26 PM
ThePizzaC5's Avatar
ThePizzaC5
Default Intermittent turn signals?
Just wondering if anyone has any advice as to why my turn signals have decided to start working intermittently today. Hit the stick, nothing, flip it the other way, nothing... and then a few seconds later, I hit them again for another turn out of habit, and they work fine. No codes - not like I'd have anything.
Thanks for any advice/info.
Old May 4, 2006 | 06:29 PM
chaase's Avatar
chaase
St. Jude Donor '12
Hazard switch is usually the problem..If it starts to work after messing with the switch you need it replaced.
Old May 4, 2006 | 08:05 PM
mitchcole's Avatar
mitchcole
Had that happen once. The next time I started the car - everything worked fine....... Haven't looked any further into it. I'll be interested in your findings.
Old May 4, 2006 | 08:20 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
Headlight switch is going out.
Old May 5, 2006 | 12:29 AM
C5Jimmy's Avatar
C5Jimmy
Had the same exact problem two weeks ago!
Hasn't happened since, very strange...
Old May 10, 2006 | 10:47 AM
jdmvette's Avatar
jdmvette
Night Owl for life
it's the hazard switch.
touch it next time you're sitting at a stop light with the blinkers on. you can feel the blink of the blinkers on the hazard switch.
this is your problem.
To Intermittent turn signals?
