I have oil in my intake ports, and it's worst at the front of the motor. I am assuming this is probably from the LS1 PVC system. My question is, is this much oil normal? And would this be a problem for the Supercharger I am putting on, as far as detonation? I just paid over $100 last year, and probably not even 500 miles ago, for Chevy to Decarb the motor. Looks like to me they didn't do a very good job.
I don't believe he needs a catch can on a '99. IMHO.. If he has an after market intake..K&N, Blackwing....may have too much oil on the filter..could be PCV issues also..decarb takes place in the upper cylinders...someone will chime in with the answer...
Catch can collects a lot of oil, but won't eliminate this. I just changed heads and have a catch can, there was oil in the intake ports still yet the catch can was filling up as well.
I would say it is normal. I have a 1998 with stock intake and I noticed a lot of oil when I replaced my Oil Pressure Sensor. I checked into installing a catch can, but have not done it yet.
I installed a Vararam about 100 miles ago, but this oil isn't from a air filler being over oiled. That would be a lot of oil. Plus I would have some serious MAF issues. The TB was completly dry on the front side. I am 99% sure this is being pulled in from the PVC.
I have a brand new AMW catch can I will be installing with the Magnacharger. I am more concerned if I have a ring or valve guide/seal problem from the oil, or is this amount seem to be typical?
Even a good catch can, like the AMW, on the PCV line won't keep all the oil out. Oil also enters the TB through the fresh air line at WOT so a catch can is needed on that line as well. Since my car's a track car and always at WOT, I'm going to try eliminating the PCV system by using a breather in place of the oil filler and capping the manifold and TB fittings. I'll find out in a couple weeks if this set-up works.
I looked inside the intake ports of the magnacharger that is suppose to only have 4000 miles, and it too has oil inside the intake. My stock intake is really wet. I guess it's normal. I sure not like it though. Oil turns into carbon inside the combustion chamber, which will make Hot Spots in the combustion, which equals KaBOOM from detonation.
Every time I have a question today someone beats me to it Your engine looks just like mine Hate to break it to you but I'm at 87k. Anyway, now I'm not too worried.
I had a LOT of oil going into my 99's intake and head ports too. I put an LS6 PCV system on and an AMW catch can and still got a lot of oil. Then recently I re-plumbed the system and put the PCV valve BEFORE the can and the catch can to the manifold through a cheap paper fuel filter. Now I am catching oil, plenty of it, in the can and NONE in the filter. I'm going to put another 1000 miles on the car this way, measure and mark the catch can, then remove the paper filter, and do another 1200 miles that way and see what the difference is.
FWIW I also have an AMW catch can between the air bridge, used to be the throttle body, and the valve cover. I've had it on for 9 months and haven't caught a drop there. The front of my throttle body is dry, and I even removed the oil galleys and seperator from inside the valve covers. I am using Jesel SS rockers. I go WOT a lot and have never had oil in the second can.
If you put a catch can on and put the PCV valve before the can I think you will catch a lot more oil and keep your intake ports much cleaner than if you keep it plumbed like stock.
Good solution a lot of us may try, Arkay99.I have a lightly used 2003 LS1, with 3300 mi. & still saw a puddle of oil at the front of the intake ,when I took of my TB! Oil appeared to be all the way to the back of the manifold,but not as much as in front.This is with a C5 with only a few miles!?
Still think I'm going to put in a oil breather to help.Does anyone know where to get one that'll fit a C5?The universal ones wont fit without modifying the filler cap.I've asked before here how on remove the oil filler tube but no one seems to know how.You could probably get a universal one on if we could figure out how to get the tube off?
I am not following you 100% Are you saying put the catch can between the PVC, and the T.B.?
Or are you talking about putting the catch can between the PVC, and valve covers?
Got Pics?
PFYC is one place to get one. Thunder Racing's another.
NOTE: Make sure to test fit everything first before closing the hood. If there are clearance problems, stop and find out why. On Corvettes, for example, you'll need to remove the black plastic filler neck that the oil cap goes on before installing this unit.
Hood clearance is not an issue. Just unscrew the filler neck and replace it with the breather. The breather requires no more height than the filler neck does. However, since the breather comes straight out from the valve cover, the engine covers will need to be modified. On my car I don't use them.
Got Pics?
I'm not quite following Arkay either, pics or a sketch would be very helpful.
Thanx for the link on where to buy,but how do you get that pesky fill tube off to get that breather on?I tried twisting & yanking both ways,& man that thing just wont budge,there a special way it comes off?Any one have any success without taking off the valve cover?
