EBTCM and LS1 Edit
Old May 5, 2006 | 11:41 AM
dmcantrell's Avatar
dmcantrell
Default EBTCM and LS1 Edit
I am having my EBTCM replaced, and I was wondering if this replacement would affect the LS1 Edit work that I had done by John and Co. at 21CMC.
These are separate computers, correct? I apologize for not knowing the correct terms...
Is there anything I should be concerned about? Will my LS1 Edit settings be overwritten?
Old May 5, 2006 | 09:20 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Yes the PCM and EBTCM are separate. Your tune isn't at risk w/ the EBTCM replacement - as long as they don't decide to do any PCM updates while they're at it. You might make clear when you take it in that you do not want any PCM calibration updates performed.
