Fuel Gauge Quit Working!!
Old May 6, 2006 | 12:07 AM
cooluhl's Avatar
cooluhl
Default Fuel Gauge Quit Working!!
So, I fueled up today and took my son to have dinner with my wife, who is working swing shifts. About 35 miles into my fill-up, I stop at a store to check out some stuff. When I come back out and fire up the beast, all the gauges pump, but the fuel gauge went back to "E" and my "Check Gauges" light came on. What the? Any ideas? Do the gauges all run on separate fuses (it's dark out, so I haven't checked anything electrical yet).
Thanks in advance for any advice.
Old May 6, 2006 | 12:56 AM
CARRJET's Avatar
CARRJET
Try putting some Techron in and take some curves pretty agressivley, then turn key on and off several times. do a search on the forum and see what others have done, hope this helps, good luck
Old May 6, 2006 | 08:29 AM
rws.1's Avatar
rws.1
This is one of the most frequently reported problems.
IT can have 3 causes with separate fixes.
1. Cause -a fouled sending unit... sulphur compounds in gasoline with ineffective detergent package coat and foul the sending unit
Fix step 1 - treat with a strong Fuel system cleaner ( Chevron Techron, Valvoline Synpower , Valvoline high mileage, Chemtool B-12 etc) IT may take 2-3 tankfuls.
step 2- switch to a top tier fuel www.toptiergas.com
I use Shell V-Power exclusively
2. Cause - faulty electical supply due to a corroded ground.
Fix do a search find the post with location and photos of the offending ground , clean the ground connection.
3. Cause- faulty sending unit.
Fix - replace the sending unit
Try the fuel system cleaner first and switch gas at the same time. That fixes the problem about 90% of the time
Old May 6, 2006 | 10:32 PM
LoneStarFRC's Avatar
LoneStarFRC
What he said.
Old May 7, 2006 | 02:09 AM
johnvc's Avatar
johnvc
5th Gear
Default Fuel guage
When it first happened to my 05, I asked the dealer. The dealer suggested that I check the alignment and seal
of the gas cap. If not tightened securely, some ambient air may have leaked into the system, causing
the sensor to think no (or little gas). What I did was to remove the cap completely, then tighten
and see what happened. Sure enough, next time I started the car, the gas guage was at E, but then
slowly started to climb to the right, until it finally reached F.
I've found that this problem usually indicates something with too much air getting into the
fuel line at gas cap. Loosen then tighten seems to be the charm (at least for me).
Old May 7, 2006 | 02:14 AM
AtHomeSoda's Avatar
AtHomeSoda
Default wow....
That is a first...
Old May 7, 2006 | 08:44 AM
SFHC6's Avatar
SFHC6
Default "Service Fuel System"
I just had this happen to my '05 yesterday. The gas gauge went to empty and a message appeared... "service fuel system". The gas gauge fluctuates and everytime it goes to empty this message appears.
Later... the check engine light came on as well. Is this the same issue as everyone else or something different?
Old May 7, 2006 | 12:04 PM
W Muller's Avatar
W Muller
Your right tank fuel level sender is probably dirty. It’s common problem. Techron helps clean it. The way most cars work the sender is submerged in gasoline almost all the time. Your Corvette has two gas tanks. The way the Corvette fuel system is plumbed the right sender is only submerged in gasoline until the fuel level goes below ½ tank. Then the right tank is empty and the sender is in gas fumes only. If you are mechanically inclined, the sender is not too hard to clean. If you clean it you will see the problem. The resister will have some build up on it causing some of the windings to short out and cause an incorrect output. Do a search on fuel sender and there should be a procedure on how to get to it. A pencil eraser and some contact cleaner work well to clean it. If you use techron make sure you have at least ¾ of a tank of gas or you won’t get any techron into the right tank. My experience is that techron works somewhat but cleaning really works.
Old May 8, 2006 | 01:15 PM
cooluhl's Avatar
cooluhl
The only light that came on for me was the "Check Gauges" light. Not my Check Engine light. Sounds like you have a different problem.
Thanks to all for the replies. I bought some Techron and will try it first. Weird thing I already use Chevron gas with the Techron in it.
Maybe I'll just start running Nitro!!
Old May 8, 2006 | 05:17 PM
SFHC6's Avatar
SFHC6
I tried the gas cap first... re-tightened. Started it up and the gas gauge went back to normal. After a couple drives... shutting off the engine and re-starting, the check engine light went out as well.
I also posted under C6 and found that my issue may be related to a "fuel card". I guess some other '05 owners had the same issue.
For now, mine seems to be back to normal.
Good Luck "cooluhl"!
Old May 8, 2006 | 05:38 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
I tried the Techron and it worked for 6 months, but when the same symptoms you describe occurred to me, I ended up with the fuel sender and O2 sensors being replaced by GMPP just last month. Thank you Dennis Fichtner for the extended warranty
Old May 8, 2006 | 06:49 PM
CaptKirk's Avatar
CaptKirk
I can't believe that GM still hasn't solved this problem in C5s! One of the sending units was replace in my 2000 under warranty when it had less than 7M miles on the car. Since then I've had the fuel gauge go to empty twice with more than 1/4 tank. Both times I used a fuel system cleaner and have used Chevron fuels since with no problem.
Drive on!
Old May 9, 2006 | 12:12 AM
Bill Dearborn's Avatar
Bill Dearborn
Same thing happened to me the other day. Gauge was working fine when I stopped to fill up with a little less than a quarter tank. Station had just switched from Exxon to Valero and I filled the tank to the top. When I started the car the gauge went to E and stayed there for about 15 minutes and then went to full. After that it started working correctly again until yesterday. At just below a half tank the gauge dove to E and stayed there.
As for switching to a toptiergas there aren't any of those brands within several hundred miles of me and I have no idea where to get the additives mentioned in one of the posts above. Was at Advanced Auto today and did not see any of those listed.
Bill
To Fuel Gauge Quit Working!!
