No Compression
Old May 6, 2006 | 10:06 PM
TACOBOB's Avatar
TACOBOB
Default No Compression
Anyone might know why I lost almost all compression? Going down the highway about 130 on juice pulling strong then car shuts down won't start. Plugs are fouled checked all fuses, maf ok. Compression is zero in 3 cyl ,40 psi in one. Did a wet one in one of the cyl with zero and no change. l
Old May 6, 2006 | 10:10 PM
LoneStarFRC's Avatar
LoneStarFRC
Any broken valve springs? Pull the covers and check for this or any bent valve stems keeping the valve(s) open. Open valves=0 compression. HTH
Old May 6, 2006 | 10:15 PM
TACOBOB's Avatar
TACOBOB
Yea tommorow gonna pull the covers and see if the valves are opening and closing. Next is pull the heads. Worst case is rings but it just seems strange that they all go at the same time
Old May 6, 2006 | 10:18 PM
jers98vet's Avatar
jers98vet
How many miles on the engine? I'd suspect a timing chain.
Old May 6, 2006 | 10:19 PM
TACOBOB's Avatar
TACOBOB
Didn't mention that I didn't check the other four cyl compression cause the engine was cranking so fast with plugs in I didn't think ther was much comp in any cyl.
Old May 6, 2006 | 10:20 PM
TACOBOB's Avatar
TACOBOB
45000 miles Just had new cam and heads installed about a 1000 mi ago
Old May 6, 2006 | 10:24 PM
LoneStarFRC
Could be a broken retainer or keeper(s) too. Anything keeping those puppies open. I'm betting on valve vs. rings. Let us know.
Old May 7, 2006 | 02:55 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Most likely ring lands broken / piece of a piston gone. "on the juice..." Sorry.
To No Compression
