code P0153 after header install
Old May 6, 2006 | 10:19 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default code P0153 after header install
Just installed longtubes and now I have this code. Why would it have an O2 code just from installing headers?
Old May 6, 2006 | 11:40 PM
Cruzzn's Avatar
Cruzzn
you sure it's 0153? Mine threw a code of 1153. Which is o2 sensor. if it is just reset it.
Old May 7, 2006 | 12:07 AM
mvvette97's Avatar
mvvette97
Yea it's P0153 heated O2 sensor. It's a Bosch sensor. I had some trouble before. This is the second time I have had this problem. The other side is the AC delco sensor and so far it has been fine. Maybe the bosch sensors are junk.
Old May 7, 2006 | 03:04 AM
oahuyahoo's Avatar
oahuyahoo
Its from the sensor located by the cat, cats are not gettinghot enough.
Old May 7, 2006 | 03:12 AM
killaz's Avatar
killaz
not sure of your year, but if you have air tubes, check to see if the gaskets are good. I got that code untill i fixed it with new gaskets.
holla
Old May 7, 2006 | 08:24 AM
shulamite's Avatar
shulamite
Default 02 sensors codes
I had the same problem after lt headers and cats. I was instructed by lg motorsports,972-429-1963, bobby, to move the rear cats to the front locations, as they are hotter and will send the correct info to the computor. Also you will need to install 02 simulators on the rear connections and convert the front connection to rear type with adapters available from lg motor. It sounds a little complicated but the only difficult part was securing the wires in their new location away from hot exhaust,. I ordered high temperature tape wrap from summitt racing, wrapped all wire and connection and added some new attachment points with zip staps. It is tight up there so take your time and secure everything well. I even added two holes in the pinch welds you will see to accomodate the zip ties. This works but it is a pain in the ***. Still it was worth it. good luck!!
Old May 7, 2006 | 10:37 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
holla
If that doesn't fix it, get a matching GM sensor. I've got almost 1K miles on my install and 0 codes.
Old Jun 4, 2006 | 05:07 PM
Wake Champ's Avatar
Wake Champ
Default P0153
I have this same code. Is this something that MUST be fixed? Or can I ignore it and not worry about it?
Old Jun 4, 2006 | 08:50 PM
Bob Chapman's Avatar
Bob Chapman
Mvvette-This code indicates improper heating of the front 02 sensor on the passenger side. I had this problem after installing LTHs and finally had my tech switch the 02 sensors from side to side thinking that if I got the code for the driver's side it would mean the sensor was bad. Since the sensors were switched about 300 miles ago I have had no codes. Tells me that the drivers side sensor connection was not good. Suggest that you have connections checked and ground 105 checked.
Bill Curlee on the Forum is also a very good source for constructive solutions.
Old Jun 5, 2006 | 01:54 PM
zeevette's Avatar
zeevette
I've been running for well over a year with two codes 0133 and 0153 after I installed my Lgs. I don't have cats, and I used sims for the rear.like instructed. Doesn't seem to affect the motor, but when I finish modding, I'll get it tuned out.
Old Jun 5, 2006 | 09:24 PM
82shark's Avatar
82shark
Thats odd, after LT's and no Cats, I got 0134 and 0154, but I forgot to plug the O2 extensions back in, now I get an 1133, which is the heated O2 sensor code.
Old Jun 5, 2006 | 09:31 PM
mvvette97's Avatar
mvvette97
Well guys, I put a new O2 in and haven't had a problem. Maybe it just went bad.
To code P0153 after header install
