tire on backwards
Old May 7, 2006 | 06:19 PM
Young_Z06's Avatar
Young_Z06
Default tire on backwards
standing in the driveway today looking at my vette and it dawned on me for the first time that something looked strange about the rear wheels. the tread pattern looked the same on both sides instead of being symmetrical. closer inspection on right rear, sidewall clearly states that "this side inward".
i bought the car from a dealer last fall. have only put about 2,000 miles on it, mostly last fall and this spring. it has gotten a little squirelly a few times, but i thought it was just the few times I hadn't totally let the tires warm up. now that i think about it, it has always been to the side with the tire on backwards.
obviously, it's something i need to get fixed. my question is if the tire is toast or can it just be turned around. according to service records on the car i got from the dealer it was installed at 17,190 miles, so the tire only has about 3,000 miles on it.
not real enthused about going back to the same dealer that already installed the tire backwards, but if I need a new tire, i intend to at least make a stink about getting them to pay for it.
any advice would be helpful.
thanks,
Old May 7, 2006 | 06:24 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
i doubt there is anything wrong with the tire no real wear issues would have occured and that is all i would think you should be worried about.
Old May 7, 2006 | 06:34 PM
Oldvetter's Avatar
Oldvetter
One magazine tested directional tires mounted backwards, they didn't find a lot of difference. When steel belted radials first came out, the recommended you only rotate them front to back. Supposely changing direction could cause belt/tread seperation. Now most manufactors recommend "X" rotation. I have stuck to front to back (except Vette, of course) because it's easier to do at home (lifting one side of car at a time).
Your tire will be fine, just tell them to be careful of tire pressure sensors, a lot of people are not used to them.
Old May 7, 2006 | 08:59 PM
TEXHAWK0's Avatar
TEXHAWK0
If they are F1 Supercar tires, they are asymetric but not directional.
That is, they have an inside and an outside, but can rotate either direction. I rotate my Z06 tires from side to side all the time.
I have a spare front and rear wheel/tire mounted up, and every 6,000 or 7,000 miles I rotate the set of spares onto the right side of the car, move the right sides to the left side, and the left side tires become the spares.
Old May 7, 2006 | 10:31 PM
MawneeC5's Avatar
MawneeC5
I once was riding with someone that had a used tire on the rear mounted backwards. It was an old 80s buick regal or some such. We were goofing off and he locked up the brakes. The tire blew on the spot. When we went to pull it off we got our hands shreaded becuase the radial metal wire had pushed through the tire. It looked like a spiked tire, little metal wires sticking out 1/2" slanted against rotation all the way around.
I dunno..I'd take it back to the dealership myself. If nothing else, make them say its OK, so if something happens they are responsable.
Old May 8, 2006 | 10:02 AM
yellow01's Avatar
yellow01
I would make 'em fix it. Period. They're boneheads, make them make it right.
As far as directional - most tires are fine in the dry either direction. Most of the directional design is related to water and dispensing with water, so you may have less than optimal wet performance. You may never notice.
Either way, I'd make 'em fix it on principal.
Old May 8, 2006 | 12:36 PM
adown's Avatar
adown
If there is an arrow on it, it is meant to roll that direction. It has to do with the way the belts are laid. Have them change it before it causes any problems.
Old May 8, 2006 | 01:09 PM
pjm710's Avatar
pjm710
If they cant put the tire on the right way dont go to them for anything else.
Old May 8, 2006 | 02:38 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
To tire on backwards
