Firestone Wide ovals
Old May 7, 2006 | 10:20 PM
Its_Go_Time's Avatar
Its_Go_Time
Default Firestone Wide ovals
Does anyone have any experience with these tires? My traction control/active handling is on 24-7 with these damn things. When I switch it all off, the car just won't hook up...one of these days I'm gonna get smoked by a corolla...
Old May 7, 2006 | 10:27 PM
Kappa's Avatar
Kappa
They are pretty good tires and are especially good in the wet. They have great bang for the buck.
Old May 7, 2006 | 11:39 PM
usd2sing's Avatar
usd2sing
mine are great!!
EDIT: play with your air pressure. it made a diff on mine. 32front, 28-30 rear.
Old May 8, 2006 | 09:30 AM
Uncle John's Avatar
Uncle John
You might want to check in the Z06 section. They're kinda' popular with that crowd.
Old May 8, 2006 | 10:31 AM
MR1911's Avatar
MR1911
with above tire press is key
Old May 10, 2006 | 12:10 PM
rstrautman's Avatar
rstrautman
Default Pressure
...I run these and luv em', for hard power driving use 30 psi in the rear and give a couple miles to warm-up, u should be fine. Definetly good tires for the money
Old May 10, 2006 | 12:32 PM
sick-c5's Avatar
sick-c5
I run them on my z. luv em
Old May 10, 2006 | 01:31 PM
DPG's Avatar
DPG
St. Jude Donor '06
what size tires did you get? are they stock size or did you go bigger/smaller than original?
Old May 10, 2006 | 02:11 PM
usd2sing's Avatar
usd2sing
295 265's here....z06 stock sizes. wider foot print than my stock c5 sizes.
Old May 10, 2006 | 02:30 PM
QuikZilver's Avatar
QuikZilver
I am running the Wide Ovals both on the street and on the track. On the track, I was getting a lot of hopping until we started playing with tire pressure. Last weekend, I dropped the pressure to 28 lbs on both sides and hit a 1.737 60' time (needless to say, I was since my 60' times are normally around 2.2). That was with Comp mode turned on. I drive around the water box and back in to wet the rears and then nail it in 1st to spin the tires (basically, cleaning them). On the street, I always have TC/AH on and I don't nail the throttle off the light, but the Wide Ovals stick much better than the Supercar F-1's on dry pavement or on wet. I am very happy with them!
Old May 10, 2006 | 11:09 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
We've got a set on one of our 93 Trans Am's and love them. Car hooks great in the dry and pretty dang well in the wet, and this car is making 345/360 to the ground.
Old May 11, 2006 | 11:15 AM
patrickC5's Avatar
patrickC5
when they are cold they suck of course but like was said before warm them up a little and the hook great, at least thats the way mine are!
To Firestone Wide ovals
