Jacking Question:
Old May 7, 2006 | 10:52 PM
GMvert's Avatar
GMvert
Default Jacking Question:
Stupid is as Stupid does, will I be safe with a 1.5 ton jack just lifting to put stands under the vette or should I go with a 2-3 ton jack?
Old May 7, 2006 | 11:15 PM
RWVH's Avatar
RWVH
I would go with a 3 ton Sears, I have one if you need to borrow it.
Old May 7, 2006 | 11:46 PM
BanditDude's Avatar
BanditDude
The whole car only weighs about 3200 lb. You'll be fine.
Old May 8, 2006 | 09:41 AM
rws.1's Avatar
rws.1
If you are jacking the whole front end via the cross member, you will be al the limit of your jacking power....
A larger capacity jack would be safer....
Old May 8, 2006 | 10:03 AM
yellow01's Avatar
yellow01
I like margin I don't know how much margin the jack designers put into the #'s, I'm sure there's some, but I like lots Afterall, if it fails, bad things can happen...
To Jacking Question:
