need brake help!!
Old May 8, 2006 | 08:01 PM
c5vette_dallas's Avatar
c5vette_dallas
Default need brake help!!
the is a squealing/squeakin somtimes just cruising down the road and when i lightly push the brake pedal(not even enough to start slowing the car down)..any one ever had this problem!! HELP it is getting annoying!! have replaced rear pads and i believe the front pads are good..
Old May 8, 2006 | 11:55 PM
Bill Dearborn's Avatar
Bill Dearborn
Are you sure it isn't the pad wear sensors? If the pads need to be replaced they squeal when your foot isn't on the brake. They are located on the trailing edge of the inboard pad at each wheel. They usually do not make any noise until there is 2/32" or less of pad material at that point but could be bent in.
Bill
Old May 9, 2006 | 08:57 AM
c5vette_dallas
the back pads were probably 2/3's done...but the back has new pads now and its still squeakin
Old May 9, 2006 | 10:05 AM
yellow01's Avatar
yellow01
And this is a problem?
Honestly, if it's just a light press (enough to put pads against the rotors but not much pressure) it is not atypical for some noise. If it goes away as you put more pressure then don't sweat it.
To need brake help!!
