engine oil temp LOW?????
Old May 9, 2006 | 09:19 AM
burnin red's Avatar
burnin red
Default engine oil temp LOW?????
I put a 160 degree thermostat in my car and adjusted the fans, now when I check the gauges it just says oil temp LOW is this bad or ok, the coolant is running about 190 and it is about 65 degrees outside, the car is 1998 coupe, please help thank you
Old May 9, 2006 | 09:23 AM
yellow01's Avatar
yellow01
Never seen a low TEMP warning, sure it isn't a LOW LEVEL warning?
In general it is good to get oil up above 21x in order to keep out moisture. With my oil cooler I run cool on the street but get it plenty hot on occasion on the track.
Old May 9, 2006 | 11:19 AM
11sec_C5Z51's Avatar
11sec_C5Z51
i have the same problem on my '02 coupe. someone told me it was the oil temp sensor located in the oil pan...they said it's either dirty or just have gone bad...
Old May 9, 2006 | 12:42 PM
SFVetteman's Avatar
SFVetteman
Using the 'gages' button, cycle through the display until you come up with the oil temp display. I have never heard of a low oil temp warning before so it's either a bad sensor or a mistakenly read low level warning as others have said.
Old May 9, 2006 | 10:51 PM
burnin red's Avatar
burnin red
sweet, will check out the sensor, you know it never did it till I put in the 160 thermostat though? I will check it though
Old May 9, 2006 | 11:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
This typically occurs at sub 15 degreee temps.
I've seen the "low" oil temp reading many times. If it's that cold, it's normal.
But since you're posting this now, i can't imagine where in the world you are (other then Antarctica) that this might be a legit reading. Probably a sensor issue.
Old May 10, 2006 | 02:50 PM
JC in XTC5's Avatar
JC in XTC5
Same here. In cold climates, the oil temp will sometimes read LOW instead of a value and remain that way until the next time the car is started (assuming the oil temp is above the minimum temp).
Since you're not in that cold of a climate, the sensor is probably bad, but check the temp sensor connector. If the connector is either open or short circuited, it would likely give and extreme hot or cold (i.e. LOW) value - corrosion may also have an effect. Otherwise you'll need to replace the sensor.
Old May 10, 2006 | 03:34 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
To engine oil temp LOW?????
