Has anyone thought of or tried any type of injector displacment, like shuting down cylinders to improve mpg while traveling long distances?
What would it take to make this possible?
The process just shutting injectors down is much more complainted and it can burn up your cyclinder since gas is also a forum of lubication. Thanks
To make it possible it would most likely take more money then you would save in gas.
Ain't that the truth. If I get 31.5 mpg at 75+ mph in moderately hilly terrain, I'll just leave this bad boy alone. Turning off the injectors has to be accompanied by a way to keep the exhaust part way open on the compression stroke of the dead cylinder or otherwise the work to compress plain air destroys any fuel savings.
Side note - it is amusing that hybrid sales have tanked. SOMEBODY finally figured out that the mileage improvement combined with the higher purchase cost, combined with buying a multi-thousand dollar battery pack sometime in the future wasn't good economics. And still others figured out that all the fuel savings come from not having the gas engine running while sitting in traffic and using braking energy to charge the battery pack. There is NOTHING magic about a hybrid. It is nothing more than a REALLY good computer that does a great job of managing resources effectively.
Charlie
Naw, most of that energy is recovered when the piston comes back down on the next stroke. It's like compressing a spring, then releasing it.
:... There is NOTHING magic about a hybrid. It is nothing more than a REALLY good computer that does a great job of managing resources effectively.
Charlie
Most of the hybrids are small and aerodynamic to begin with, with exception of the SUVs. There are 6 speed diesel compacts getting better highway mileage then the hybrids at a much lower MSRP.
So for urban driving they do help because they shut off and don't idle, but I heard if you want to run the AC that the engine needs to say on, not sure if this is true on all models.
that you'd be better served fertilizing a corn crop to make ethanol for E15 or E85.
The list of devices that have made their way to market in the last 50 years is astounding, from the thing that bubbled some of the intake air through water to add moisture, to the magnets that "aligned" organic, non-magnetic fuel molecules to the magic pills you put in your gas tank (may have seen these coming back). About the only thing more interesting is the list of add-ons that increase horsepower from 8 to 40, yet the results never seem to show up on a dyno. Maybe two years ago Corvette Fever announced they were going to run a series of articles on various "high-flow" air filters, devices that smoothed air intake flow, devices that added turbulence to air intake flow (figure that one out - if you put in the smoother AND the turbulence generator, how much could it make ) and more. They were going to put this amazing parts on cars and then put them on a dyno to measure the performance increase. The first article dealt with various air intakes. The horsepower increase ranged from zero to less than 10 increase, and NONE of them made the increases we hear about that gets the plastic off our hip. It was also the ONLY article that ever ran in the series. I wouldn't suggest for an instant that having advertisers be embarrassed when the numbers didn't move much, if at all, had anything to do with the series dying. Nope, wouldn't suggest that at all. Wouldn't be proper. As a matter of fact, they probably ran the tests on an improperly calibrated dyno and there really is a 12 hp gain from using a left hand threaded swirl pattern into the MAF rather than a right hand thread. It could happen.
You're kidding, right? My 99 with 6-speed STILL routinely gets 30 MPG
on long trips. And that's not going by what the DIC says.... that's actual calc of miles divided by gallons-to-fill!
Why would you want to fool around with that kind of tuning?
Drove from Nashville to Toledo, 489 miles, filled up in Toledo, averaged 31.5 mpg and ran 75 - 85 all the way and one blip to lower mid 3-digits indicated when I had an open stretch of about a mile. And it has 80K on the clock. I have had it about two months and just had to spool it up at least once. It seemed like it was starting to run out breath in 6th gear when I backed out of it even though the engine was only turning maybe 3300 rpm or so.
Charlie[/QUOTE]
You guys are just skeptics, I'm going to order 3 or 4 units and install them on my vette so i'll never have to buy gas again.
Norm
It is a complex calculation, but I have just figured that if I put 11 of these hydrogen generators on my '98 along with 9 sets of the magnets that it not only will dyno nearly 800 hp at the rear wheels but actually MAKE gas that I can sell/give back to Exxon. Now all I have to do is figure out how to haul the 12,000 lb trailer that has the batteries for the H2 and magnet units.
I have a 99 FRC, 63k, Callaway Honker intake, LS6 intake, long tube headers, hi-flo cats, x-pipe, B&B bullitts, lowered, dyno tune, cam, blah, blah, blah and STILL get around 16mpg in town and last cruise averaged 33.4mpg @ 75-80mph (and I'm not a light foot either but haven't had it over 180......yet!). Better MPG than my neighbors Corolla which really chaps his A--!!!!!
No complaints and ain't looking to improve it, just DRIVE it!!
