What Size Tool??
Old Aug 23, 2001 | 04:31 PM
l2vette's Avatar
l2vette
Default What Size Tool??
I am about to change My tranny and rear end fluid to Red Line, can anyone tell me what the fill and drain plug tool is??
[Modified by l2vette, 8:55 PM 8/25/2001]
Old Aug 23, 2001 | 04:42 PM
jt93's Avatar
jt93
Default Re: What Size Tool?? (l2vette)
you could have picked a different topic for this question. i thought it was a new poll. to which the answer would have been.....
x-large
really have nothing usefull to contribute, just hadda comment on the choice of topics
Old Aug 23, 2001 | 04:52 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: What Size Tool?? (jt93)
:bb
Old Aug 23, 2001 | 10:24 PM
l2vette's Avatar
l2vette
Anyone know for sure????????? :confused:
Old Aug 23, 2001 | 10:34 PM
BruceF's Avatar
BruceF
The differential takes a 10mm hex-bit socket.
The transmission just uses a 1/2" socket wrench.
Old Aug 23, 2001 | 10:43 PM
l2vette's Avatar
l2vette
Default Re: What Size Tool?? (BruceF)
BruceF.........Thanks! :cheers:
Old Aug 26, 2001 | 12:53 AM
l2vette's Avatar
l2vette
Well ....changing ALL the fluids in a C5 Vette, can take a little more time than I thought! I did the MN6 manual first; the plugs (fill and drain) use a 3/8" socket extension and came out with no problem. OEM ATF outta there!!
The New Redine D4-ATF bottles need a special handpump, I did't have one!!
So I cut the bottle off at the neck and turn that piece upside down and put it back in the opening of the the now modified bottle. The hand pump I had worked great then!
The differential fluid was easier, using a 10mm hex, I noticed more deposits on the drain plug than the tranny. Back in went Redline 75-90W.
Then the LS-1, I ve done before , but after the tranny and the rear end, I was ready for a break! All said and done, It FEELS GOOD!!!! Must be about 10 HP GAIN with ALL SYNTHETICS!! :cool:
To What Size Tool??
