Help Check Engine Light
Old May 14, 2006 | 11:43 AM
plumberh2o's Avatar
plumberh2o
Default Help Check Engine Light
Out of no where I get a check engine light. I have the Predator Programmer & diagnostic tool.
How do I find out what is wrong.
Ken Thanks
Old May 14, 2006 | 12:21 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Ken Thanks
Here you go. http://www.97vette.com/howto/codes/index.html
Old May 14, 2006 | 12:42 PM
plumberh2o's Avatar
plumberh2o
Thank you for your help. I have a 2004 coupe will this list still be good for my car.
Ken
Old May 14, 2006 | 03:14 PM
mvvette97's Avatar
mvvette97
Ken
Yep
Old May 14, 2006 | 04:04 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can also go to this one!!!
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/index.html
http://www.corvettedoctor.com/index-1.html
http://www.corvettedoctor.com/Code_Main.html
Select: Technical Data Base, then 1981-2004 Corvette ECM Computer Codes, Then your year C5, then read the directions. At the bottom of the directions page you will see “READ MORE”. The codes are on that next page.
The sound effects are cool too!!
Bill Curlee
Old May 14, 2006 | 04:45 PM
plumberh2o's Avatar
plumberh2o
Thanks for the Info,
But what does 10PCM mean. 1 code. Did I miss something?
Old May 14, 2006 | 04:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep!! You need to press the options button to enter the manual mode. Once there, press fuel or trip to scroll up or down through the codes (if there were more than one) Everytime you press options or gauges to scroll up and down through the modules (pages), you will enter a new module BCM ICP LDCM RDCM SCM RFA HVAC RADIO ect...... If you want to clear the codes,, press and hold reset. If you press English/metric it will exit the Diagnostic mode
Old May 14, 2006 | 05:15 PM
plumberh2o's Avatar
plumberh2o
I cleared the code so now I have no way to tell what it was?
Should I get rid of all the H -codes so I will be able to find out witch one comes back if and when it does?
Ken
Old May 14, 2006 | 05:18 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
No problem! Trust me,,,if there is a problem,, the code WILL reappear!!! Yep, clear them all and see what comes back! Always maks sure that you include the C and H sufix. Its important.
Bill
Old May 14, 2006 | 05:28 PM
plumberh2o's Avatar
plumberh2o
Thanks For your help Bill.
Ken
To Help Check Engine Light
