My LS7 Clutch Observations
Old May 23, 2006 | 08:37 PM
LightFighter_GXP's Avatar
LightFighter_GXP
I found a vette shop to do the install for $400 I think I should get the remote bleeder too? what do you think??
Old May 24, 2006 | 12:08 AM
ST0CKER's Avatar
ST0CKER
ill disagree, i went FASTER w/ the clutch then w/ the ls6 clutch. No other changes. Could be cause it gripped better but who knows.
Dave
Old May 24, 2006 | 01:17 AM
pro1955's Avatar
pro1955
Do the remote bleeder hose, now would be the time since your going in there.
Old Jul 10, 2006 | 07:44 PM
Highroller's Avatar
Highroller
Originally Posted by connecticut
Ike, interesting point, i noticed this on a recent LS7 clutch install, next one I'll have to weigh to see what the difference is
Whats the install cost and how long did it take?
Old Jul 10, 2006 | 08:26 PM
lloaf's Avatar
lloaf
Tony Mamo--What clutch are you running and is it streetable for every day traffic ? Thanks
Old Jul 10, 2006 | 08:40 PM
Warp Factor's Avatar
Warp Factor
Originally Posted by Tony Mamo
Rotating mass is the enemy....robs horsepower and will slow the acceleration of the engine (and make it slightly less responsive).
Not a good set-up if your looking to be a hero on the chassis dyno (or the track)...thats for sure.
A heavy flywheel/pressure plate combo will slow you down on the track only if your launch rpm is lower than your rpm through the traps. Additional mass could even be an advantage with tall gears, poor low-end torque, or excellent traction.
The other negative is that heavy mass single disc clutch will make lightening fast shifts at high RPM much more difficult (which I personally kind of enjoy the challenge of).
Pressure plate and flywheel mass don't factor into the speed of the shift. The synchros only need to overcome the clutch disc mass.
Old Jul 10, 2006 | 10:07 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Here's my 2 cent. I just got my car back with the LS7 set up installed. Ive only got about 140 miles on it so I have not really jumped on it. I doubt my car will see a road race or a track run, and I still think the selection was right for me.
The clutch does grabs a little lower then my stock LS1. I have the adjustable master in, but have not corrected the engaugement level yet. It not a bad engaugement level, it's just a little lower than im used to.
I have gotten on the car at 3/4 throttle once or twice, and it grabs hard. A friend of mine had about 460 HP with 3.90s and it grabs perfect. Its a great clutch for the street car with HP.
Old Jul 11, 2006 | 08:07 AM
WKMCD's Avatar
WKMCD
Phil drove my car with 460RWHP and the LS7 setup. I agree with Tony Mamo, for people wanting a stock feeling clutch that works with extra HP the LS7 is a great choice. I have't found a downside on mine yet after about 5k miles and I do "drive it like I stole it"
Old Jul 11, 2006 | 08:22 AM
VetteDrmr's Avatar
VetteDrmr
Some tracks actually have turns.
Not exactly true. An engine with a heavier mass flywheel/pp assembly changes rpm more slowly than if a lighter assembly is used. Therefore the syncros have to overcome a larger speed differential between gears. A lighter assembly also makes rev matching when downshifting easier.
Have a good one,
Mike
Old Jul 11, 2006 | 02:34 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
I have a good question for you....
Do you feel that you Lost or Gained any power "Feel" to the wheels with this clutch setup ?
I don't want to install this clutch and find the car "feels" slower because people have said its a heavier clutch set up than the LS6 clutch. I did not listen to guys here about heavier wheel weights affecting my car's performance and I sold the heavy wheels 2 weeks after I got them.
My 04 Z06 has 525HP/500Tq (LG's Heads/Cam/Headers). I can feel the clutch engagement is becomming more and more towards the highest point in the movement. Its time I start thinking about a clutch replacement.
Toque
Old Jul 11, 2006 | 03:30 PM
Warp Factor
Mike
Sorry, can't go along on that one. Speed differential between the gears is a function of transmission ratios, not engine rotating mass.
When shifting (at least if you use the clutch when shifting) the transmission and clutch disc are disconnected from the engine, so engine mass isn't a factor. Only clutch disc inertia.
Old Jul 11, 2006 | 05:23 PM
Sportsdude's Avatar
Sportsdude
Good info, thanks
Old Jul 11, 2006 | 09:26 PM
  #33
LightFighter_GXP
I had my LS7 clutch combo installed over the weekend, All I can say is it's very smooth, worth every penny!!!
