My LS7 Clutch Observations
Old May 14, 2006 | 03:42 PM
Casem1's Avatar
Casem1
Default My LS7 Clutch Observations
I figured I would post this since it seems to be a popular topic for questions.
First: Bought set up from Fred Beans. Top notch place, highly recommended.
Second: I replaced the flywheel, clutch, PP, and pilot bearing. I upgraded to the new style slave (I have a 99). NO SHIMS.
OK, right away I noticed that the clutch seemed to engage almost instantly, right off of the floor. For the drive home it seemed fine. Didn't goose it at all. For the next few weeks (my car is an occasional driver) I would put a few miles at a time on it, drove it fairly easily. Soon a noise developed when I engaged the clutch. Withing 50 miles or so the noise was gone... ?? I have no idea...
Present day: The clutch makes no noise, no chatter. It has held anything I have thrown at it (2-3 hard launches, racing through the gears in the Houston heat). Most importantly, the clutch engages at about the same point it did when I had the stock clutch! It is perfect right now. I have headers and have never had the clutch pedal stick to the floor. The only thing I have ever changed is the clutch fluid (I try to keep it clear).
All in all -> Highly recommended but would never install myself.
Old May 14, 2006 | 06:12 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
and that's why I bought this set up
bottom line, it designed to hold at least 505 HP at the fly wheel, and ill be close to that. To me, it's like replacing the stocker when the car was stock. No brainer
I added an adjustible master cylinder
Old May 14, 2006 | 07:34 PM
Scubanme's Avatar
Scubanme
I'm glad to hear a clutch setup that works. Who makes the adjustable master?
Thanks,
Old May 14, 2006 | 07:39 PM
Casem1's Avatar
Casem1
Thanks,
Cartek makes one, but like I said after about 500 miles mine engages near the stock position. Seriously, it is perfect right now, stock master. A GTO driver told me earlier the LS7 setup is self adjusting... ???
Old May 14, 2006 | 09:16 PM
Sicvette's Avatar
Sicvette
I am another happy customer of the LS7 clutch/flywheel setup in my 2000. I also upgraded to the LS6 clutch hydraulics. The clutch feels great and grabs hard! I will see how it holds up to my H/C setup going in about 3 days.
Old May 14, 2006 | 09:32 PM
kpforce1's Avatar
kpforce1
I bought the LS7 setup from Beans as well... I haven't installed it yet but I will soon!
Old May 14, 2006 | 09:41 PM
pro1955's Avatar
pro1955
I agree completely, but I did my own and wouldn't pay a shop for it, but I have a lift easy for me to say.
Old May 15, 2006 | 03:42 PM
LightFighter_GXP's Avatar
LightFighter_GXP
how much did your set up run you???
Old May 15, 2006 | 04:06 PM
QuikZilver's Avatar
QuikZilver
Was the noise you heard a loud screaching noise, almost like a bad pulley/belt? Friend of mine just put one in his 98 and just tore the rear apart trying to figure out what was causing the noise. Thanks.
Old May 15, 2006 | 04:46 PM
Casem1's Avatar
Casem1
The noise was almost a rattle. It happened when I engaged the clutch and I could replicate the noise fairly easily. More noticeable in Reverse.
The setup cost me about $500 shipped.
Old May 15, 2006 | 04:59 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
I almost went with this setup, then saw a comparison with a C5 z06 kit. The LS7 had a larger PP and flywheel which is expected since its designed for a 427ci
I didnt want to add more rotating mass and weight to my car so I backed off. Im sure its negligible, but you cant work around Physics.
Old May 15, 2006 | 05:17 PM
blkonblk_c5's Avatar
blkonblk_c5
I got the same set up through gene at fred beans only I got a new ZO6 slave and master it wasn't to bad of a job I did it with a little help on the garage floor and it too has about 500 miles on it. I like it and would def. recommend it, the only adjustment I had to make was on the upper clutch switch at the top of the pedal and that only took 30 seconds if that.
bottm line DO IT.
By the way I paid about 735 shipped and the pedal feels great. and I have no idea what people are saying about shims everything went perfect.
Jon
Old May 22, 2006 | 04:40 PM
LightFighter_GXP
I just ordered my kit and does anyone know of any good priced places in Michigan to get the clutch install done
Old May 22, 2006 | 04:47 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Ike, interesting point, i noticed this on a recent LS7 clutch install, next one I'll have to weigh to see what the difference is
Old May 22, 2006 | 10:52 PM
ST0CKER's Avatar
ST0CKER
i have about 60 passes on mine and 5or so thousand miles out of my ls7 clutch. I could cause a stuck pedal on my car at will w/ my ls1 and ls6 clutches i put in. THis one i can NOT. that was my only dislike of the car was the sticking clutch, now it seems gone. Knock on wood. BTW, this is with 1.6-1.7 60' times.
dave
Old May 22, 2006 | 11:18 PM
PUREFUN's Avatar
PUREFUN
St. Jude Donor '07-'08
My LS7 clutch has been in my 2004 Vert for about 4,000 miles with no issues. Running 450 rwhp and 500 rwtq.
Old May 22, 2006 | 11:29 PM
unstressed's Avatar
unstressed
LS7 Pressure Plate - 23.0 lbs
LS7 Clutch Disc - 6.8 lbs
Vette LS2 Flywheel - 25.0 lbs
Mine has been in for ~5K miles & smiles. Did mine on the garage floor in ~7 hrs with a 4.10 gear swap too.
No problems, smoother and stronger than stock.
To My LS7 Clutch Observations
Old May 23, 2006 | 11:35 AM
muncie21's Avatar
muncie21
I've heard of people running the LS7 clutch and PP with a LS6 flywheel. Supposedly it only adds about 5lbs from a stock LS6 setup.
Old May 23, 2006 | 03:47 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Rotating mass is the enemy....robs horsepower and will slow the acceleration of the engine (and make it slightly less responsive).
Not a good set-up if your looking to be a hero on the chassis dyno (or the track)...thats for sure.
Barring that, the LS7 set-up is a smooth driving clutch thats perfect in a 500 ish RWHP car that the owner isn't looking for every last ounce of power from. The other negative is that heavy mass single disc clutch will make lightening fast shifts at high RPM much more difficult (which I personally kind of enjoy the challenge of). All of the reasons above is why I chose to run a lighter, low inertia style set-up (small diameter dual or triple disc). Once youve experienced the shift feel of that set-up its hard to go back....plus I love the extra "zing" the engine has with the lighter rotating components and knowing the fact I am using more of the engines power and applying it to the ground (not wasting some of it to accelerate a heavy clutch, pressure plate, and flywheel combo).
Just a different point of view I thought some of you guys would have an interest in. Once again though....for a guy looking for a "stock feel" type of clutch that can handle some HP....the LS7 set-up is certainly the ticket.
Just another .02 in the mix....
Tony M.
Old May 23, 2006 | 08:25 PM
SnowyATX's Avatar
SnowyATX
Same setup and conclusions here.
