FOB Problem
Old May 14, 2006 | 05:55 PM
2000_Convert's Avatar
2000_Convert
4th Gear
Default FOB Problem
Recently my FOB would'nt work, so I replaced the battery; reprogrammed it & worked for a day. Unlocked the car using the key, then reprogrammed again. FOB working, then in a day or so, it no longer functions. Reprogram again... get the picture. Now i'm reprogramming daily or hourly, and it'll work for a short while then fails to fucntion.
Any ideas?
Old May 15, 2006 | 12:54 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Any ideas?
I've got plenty of ideas but the only one that works is buy a new one.
If you have a second remote try that one, if not, a new one usually solves the problem 99.9% of the time.
Welcome to the Forum and the Twilight Zone of the keyless remotes!
Old May 15, 2006 | 01:35 AM
GrayC5's Avatar
GrayC5
Welcome to the Forum.
FOBs do go bad over time. Sounds like it may be time to replace it with another one.
Old May 15, 2006 | 08:07 AM
2000_Convert
4th Gear
Thanks, and thanks. Know of any reliable sources to purchase other than GM dealers?
Old May 15, 2006 | 08:23 AM
brentg454's Avatar
brentg454
Check ebay, you'll pay about 40 bucks if I remember right. Just make sure the GM part numbers on the back of the fob match up. (Mine says GM: 10432147, for example.)
HTH
Brent
Old May 15, 2006 | 01:05 PM
DAWS C5's Avatar
DAWS C5
The FOBs have weak battery contacts. When you bump it, it loses battery contact momentarily. This forces a re-sync. Open the FOB and gently pry up the battery contacts so they put more pressure on the battery. Bet it works.
Old May 15, 2006 | 01:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is something that you can try before you dump your old fob that may "still be good"!!
The main 12 VDC battery, if low/weak will start a C5 but play havoc on certain modules! Check your DTC Codes and see what codes are there. If you see tons of history codes, clear them all!! Reprogram the FOB's and when they fail again, recheck the codes. If you see a lot of U series codes, you battery may be too weak to maintain the memory functions in the BCM, IPC. When you start the car, the available battery voltage drops low. If it drops below 9 VDC, your modules will NOT be happy and shut down for a very brief period of time erasing the volatile memory's.
You can have your battery checked out at any of the local automotive stores, and sears. Make sure that they test the reserve cranking voltage capacity of the battery.
Please let me know if this helps you.
Bill C
Old May 15, 2006 | 02:06 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Yep
If your battery voltage is low your fob will not work properly
Ron
Old May 15, 2006 | 04:25 PM
MawneeC5's Avatar
MawneeC5
I had that same problem with an FOB I bought. Though mine would usually last a few days. Somewhere along the line it decided to work though, because I havent had to reprogram it for several months now.
Of course, now that I've said something....It will quit tonight
Old May 16, 2006 | 09:59 PM
2000_Convert
4th Gear
I replaced the original battery a few months ago.
I will check the codes.
Could it be a grounding problem???
Old May 17, 2006 | 01:25 PM
white top's Avatar
white top
He has it right thats how I fixed mine.
Jerry
Old May 17, 2006 | 09:32 PM
2000_Convert
4th Gear
Tried that; didn't help.
Had a bunch of codes, don't have a clue what they are!
To FOB Problem
