Dumb question about differential
Old May 15, 2006 | 08:18 PM
jgorss's Avatar
jgorss
Default Dumb question about differential
I am swapping out the 2.73 differential for a 3.42. I just drained the gear oil out of the old diff. and realized I don’t know were to add to oil back when I get the new one in. How do you add oil when the drivetrain is completely installed?
Old May 15, 2006 | 08:38 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Raid the kitchen
Try a turkey baster with a short piece of tubing in the end.
Don't get caught taking it from the kitchen!
Bob K.
Old May 15, 2006 | 08:44 PM
tiojames's Avatar
tiojames
Default gear oil
Most of the auto supply stores have a small suction pump with tubing on the end for a few bucks, works good.
Old May 16, 2006 | 10:56 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I am assuming that you have an automatic transmission, so don't forget that you will have to have your shift points reset.
Old May 16, 2006 | 11:58 AM
SFVetteman's Avatar
SFVetteman
You will need to have the PCM programmed to for the 3.42 rato as well or you will get a P1870 (transmission component slipping) code, which will cause the PCM to max the line pressure causing jarring shifts and prevent torque converter lockup.
You can avoid the code by not using the D/OD gear position unless you are going over 60 mph until you get it programmed out
Old May 16, 2006 | 01:04 PM
Bill Dearborn's Avatar
Bill Dearborn
If you are asking "where" Vs "how" it is through the same hole that you drain the fluid. Using a baster will work fine.
Bill
Old May 16, 2006 | 02:46 PM
VetteDrmr's Avatar
VetteDrmr
Bill
Bill,
For the diff?? My M6 3.42 diff drains right out the bottom drain plug. Are the A4 diffs different?
Have a good one,
Mike
Old May 16, 2006 | 04:08 PM
SFVetteman's Avatar
SFVetteman
The fill plug should be visable from the rear of the diff, to the right of the cover just below midline. The fill plug also has the gear ratio ID tag with it. The drain plug is on the bottom
To Dumb question about differential
