installing ASP underdrive
Old May 15, 2006 | 09:03 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default installing ASP underdrive
my local dealer agreed to install an aftermarket balancer for me for $150 if I supply parts.
do I need to replace both belts?
Old May 16, 2006 | 10:38 AM
molson's Avatar
molson
You will need 2 new belts.
Gates # K040410
Gates # K060775
You can double check these #'s on ASP's web site.
Old May 16, 2006 | 01:00 PM
LETHL_C6's Avatar
LETHL_C6
The 775 Gates is definately a good PN for the main belt. The AC belt is the same stock size.
Depending on their normal labor rate, I'd get that $150 on paper because it will take a good amount of time to do it since the entire steering rack has to come out. Shops around here charge close to $100/hr and this can be every bit of a 2hr job if not more.
Old May 16, 2006 | 01:28 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
they are at 60/hr for labor
To installing ASP underdrive
