High tire pressure problem
Old May 16, 2006 | 12:04 AM
batmobile2001's Avatar
batmobile2001
4th Gear
Default High tire pressure problem
A few days ago, after driving my 01 pretty hard through some backroads I got a high tire pressure reading in the LR. Came home and checked it and it was right at 32. Then I found how to retrain the sensors and after completing that the error cleared. So I take the car out for a test drive and suddenly it goes from reading 26 psi to 50psi. I rechecked and I still have aroung thirty lbs. Is the sensor just bad or is it something else.
Old May 16, 2006 | 01:19 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
First thing that I would do is make sure the tire pressure gauge is accurate! If it is,,,yea, you could have a fluke pressure sensor.
BC
