O2 Senors question
Old May 16, 2006 | 08:59 AM
MotleyDrew's Avatar
MotleyDrew
Default O2 Senors question
Hey Guys
Just a quick question.
I just did a clutch job on my 2001 Z06. I did not note which of my rear 02 sensors went to which side of the car. I am assuming that the wires plug into the plastic receptor on the same side as the pipe its in. Please let me know if this is correct or incorrect.
thanks
Old May 16, 2006 | 09:34 AM
GUSTO14's Avatar
GUSTO14
They cross over and plug in the opposite sides. i.e. O2 sensor in left bank crosses over and plugs in the right side harness...
(don't forget to add a little anti-seize to the threads)
GUSTO
Old May 16, 2006 | 09:36 AM
VetteDrmr's Avatar
VetteDrmr
I'm assuming you're talking about the rear O2 sensors that are connected to the h-pipe. If that's the case, the sensors actually cross over. However, it doesn't really matter, since those sensors are only used for seeing how well the cats are working, and don't feed back anything to the PCM as far as fuel mixture goes. There are upper O2 sensors that screw into each of the exhaust manifolds, but you'd be hard pressed to cross those.
HTH, and have a good one,
Mike
Old May 16, 2006 | 09:52 AM
MotleyDrew's Avatar
MotleyDrew
thankx boys !
To O2 Senors question
