DTC C1286 Steering Sensor Bias Malfunction
The EBTCM monitors sterring wheel position to compensate for steering/suspension wear. If a centering change is detected, the EBTCM changes the digital and analog center position.
If the centering routines change +/- 30 degrees bias value, or if the last IGN cycle bias value was out of range, a DTC sets.
Actions Taken
Magna Steer is disabled. ABS/TCS remains active.
Conditions for Clearing
Condition not present and scan tool clears DTC.
50 IGN cycles with NO DTC's detected.
Diagnostic Aids
Steering wheel rotated with steering gear disconnected.
Faulty sterring wheel position SENSOR.
Faulty EBTCM.
Repair/diagnosis requires scan tool and disabling the Supplemental Inflatable Restraint (not recommended for DIY).
Usually this code indicates a bad Steering wheel position sensor or a sensor that needs to be re-calibrated because someone turned the steering wheel with it disconnected from the steering gear.
Actions Taken
Diagnostic Aids
Faulty EBTCM.
Thanks Dan for the help.
