The past two days I started my 00 m6 (Monday and this morning) it came on saying to "Check Traction Control System" and "Check ABS" system. But after I drive for a bit to check out if the system was functioning or not (which I can't really tell) then when I shut her off and turn her back on, the lights and notification go away.
Has anyone else had this issue? What might be the cause and cost?
I noticed when I drove it Saturday afternoon, I was downshifting to slow down at a light, was went I first noticed the ABS notification came on telling me that the ABS was enabled?! Then after I stopped the light went away. May this have caused it?
I didn't know which one you needed or if the others are a consern. I suppose the one that looks most noticable was the TCS (Traction Control System)???
28-TCS:
C1226H
60-IPC:
U1064H
U1160H
A0-LDCM:
U1064H
A1-RDCM:
B2265H
U1064H
A6-SCM:
B2605H
B2606H
B0-RFA:
U1096H
U1064H
U1016H
Thanks!
Larry
28-TCS:
C1226H
Thanks!
Larry
This code indicates a bad ABS speed sensor at one of your wheels (Pretty sure the right front.) Since it is intermittent, It is probably a connector which is going bad. See this multi-page thread for more info: http://forums.corvetteforum.com/show....php?t=1285751
