Does a underdrive pulley really work?
Old May 22, 2006 | 08:25 PM
C6this's Avatar
C6this
Default Does a underdrive pulley really work?
Alright I am going to be ordering a cam here coming up shortly and was thinking that it would be a good time to install a underdrive pulley while I had the radiator out. I have heard some people say that as long as you dont have your ac while racing it doesnt help. Is that true? What type of gains do you get from this. Many companies advertise 10-15 rwhp is that right?
Old May 22, 2006 | 08:52 PM
Casem1's Avatar
Casem1
Do a search. This has been discussed recently. Opinions range from zero gain to 7-10 rwhp. Recently a before/after was posted where a pulley and ported TB were the only changes and 15hp/15lbft gains were the result.
If you are going to do it now is the time. (Casem1 kicks himself for not doing it when the steering rack was on the garage floor...)
Old May 22, 2006 | 09:00 PM
mean lx's Avatar
mean lx
Default Underdrive Pulley
I can't speak about the vettes, but on the mustangs, the underdrive pulleys would ruin the alternator if you sat in stop in go traffic for a majority of the time. Apparently the alternator was not spinning fast enough at an idle, causing it to burn up. They were worth about a tenth at the track, but it wasn't worth it to me after going through several alternators in one year. I will not be going underdriven on my vette. I will build power by other means. James
Old May 22, 2006 | 09:12 PM
tiojames's Avatar
tiojames
Default underdrive pulley
I had one for years on my Trans-Am and put one on my C5 when I installed H/C package. I never had any trouble with the alternator and have never heard of one burning up because it ran too slow. It runs the power streering pump and the water pump slower besides the A/C pump. Since the old pulley has to come off there is no additional labor other rhan pinning the crank. Be sure to use a new bolt in the crank.
Old May 22, 2006 | 09:37 PM
Dr Chill's Avatar
Dr Chill
If you're interested I still have some new UD pulleys left which retain the stock a/c belt since the a/c pulley is same as stock size but the accessory pulley is 25% smaller. No noticeable difference with p/s, water temps, or voltage. Cam change is the time to do it, and at this price you can't beat it.
$140 delivered. See my post in FS section for purchase information.
Size of a/c pulley is unimportant while racing or accelerating hard since I would hope your a/c is off and compressor is disengaged. When cruising around town, you probably don't want your a/c underdriven which may noticeably affect the cooling ability.
Old May 22, 2006 | 09:44 PM
Dark-Knight's Avatar
Dark-Knight
Yep, they do work and the best time to install is with cam replacement. I've had mine for 2 years and not a lick of problems.
Old May 23, 2006 | 03:48 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
With a cam your idle will be higher anyway, also the smaller pulley would compensate for the higher revs.
Old May 23, 2006 | 09:12 PM
barrynk's Avatar
barrynk
Interesting - I had U/D pulleys on my mustang for several years - never had any problems cooling, charging or otherwise.
To Does a underdrive pulley really work?
