Help - Active handling system + sick
Old May 17, 2006 | 11:36 AM
Blaine 2000 C5's Avatar
Blaine 2000 C5
Cruising
Default Help - Active handling system + sick
I have a 2000 C5 coupe. 501 hp at rear wheels. Centrifugal compressor with intercooler and headers twin disk clutch bigger injectors that sort of thing.
When I am going slow and turn, the active handling system applies one of me brakes????
Yes, codes, C 1287 and a bunch others shows steering wheel position indicator sensor. So I am going to replace.
Dealer says He has seen this a few times with Cadillacs and Vettes. Replaced steering wheel position sensor and corrected problem.
Any experience out there with me brothin regarding this one?
Old May 17, 2006 | 12:19 PM
Blowndave's Avatar
Blowndave
same thing happened to me. i had the "service active handling" pop up though. i replaced the steering wheel position sensor and my problem was cured!
Old May 17, 2006 | 02:41 PM
mannygmt2's Avatar
mannygmt2
same here... c1287, just had the steering postion sensor replaced last week, car is holding up well so far...not under warranty, should be max 2.5 hours labour plus the part
this is what the parts look like
Old May 17, 2006 | 07:43 PM
Raced Guy's Avatar
Raced Guy
Is this located behind the steering wheel?
Old May 18, 2006 | 03:53 PM
mannygmt2's Avatar
mannygmt2
located under the dash, its covered by that green part. in order to remove it, the whole column has to come off.
To Help - Active handling system + sick
