Need a little help with an electrical issue
Once it drys off enough that it is no longer shorting out the circuits, everything is fine again. I would check you passengers side carpets and the just under layment under the carpets to see if there wet. Just feeling the top of the carpet just wont do it!
If your car was recently in a lot of rain, i would bet you a cold one that moisture is your issue!As for the windows,, the main door wiring harnesses are known to have bad connections. Grab the rubber accordion tube that connects the door to the the body and feel the cable harnesses inside the accordion tube/harness. While your pressing on the up or down button for the window, shake the drivers side cable harnesses in rubber accordion tube and some times it will make the whole system (passengers side and drivers side) You can try to shake both.
If the shake thing works, its only a temp repair and you need to examine the connectors before it stops completely!
Please let me know how all this works out for you.
Bill Curlee
