Need information on codes
Old Aug 24, 2001 | 06:17 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Default Need information on codes
When I run the diagnostics on my new Z06 (2002) I get 3 codes under 40 BCM. They are B0502 HC, B0507 HC and B0 2482 HC. I can reset them start the engine and let it idle for just a few seconds and the codes are back. Can someone please tell me what these codes mean? Thanks in advance.
Old Aug 25, 2001 | 09:10 AM
chuckoc's Avatar
chuckoc
Default Re: Need information on codes (JerryL)
Here you go Jerry L
B0502 RH DRL Relay Circuit
B0507 LH DRL Relay Circuit
B2482 Backup Lamp Relay Circuit
Got these code from the down load in tech tips and I clicked to download the doc, as that is the only way to see all of the codes, I thinnk every C5 owner ought to download this doc, you can get it here and then scrol to bottom and down load it.
http://www.corvetteforum.cc/techtips...D=26&TopicID=1 or just down load from here http://www.corvetteforum.cc/techtips/images/IPC%20codes.doc
