Problems.....clutch master cylinder?
Now, for a little background on my car....I had it converted from an auto to a MN6 by A&A Corvettes in Oxnard, and it has a brand new Textralia clutch. I just got over 500 miles on the clutch at the beginning of the week, hence the spirited 1-2 and 2-3 shifts. Now, during high rpm shifts, the transmission does not want to go into 2nd or 3rd very easily. I have a B&M shifter and thought that could be the culprit, but now I'm guessing from what happened last night, it could be the clutch.
So, my question is, has anyone blew up a stock master cylinder before? if so, how much was the repair? and what caused it? I'm wondering if it could be how the shop installed the linkages and master cylinder...maybe it wasn't perfectly in line and under hard acceleration things went hay-wire.
Thanks,
Jeff
I'm about fed up with this car after the 6-speed conversion and I'm looking into a C6, and being done with these stupid problems.
Secondly the dealer states that the clutch might have been installed wrong - why would it take 500 miles to show up?
The master cylinder was new - right? You installed a Textrailia clutch which is a high performance clutch - did you have a stock master cylinder installed or was it upgraded too? (I would think so.....)
I don't doubt your tale of woe - I just don't quite understand all of the facts....
Second, the master cylinder came with the transmission that I bought (from a fellow forum member) that came out of a 2001 with 17K miles. I did not figure that this needed to be upgraded. Plenty of people on the forum here with Textralia and other aftermarket clutches with stock master cylinders.
Third, I have been taking it easy for the first 500 miles and did not get on it very hard. The only time it started acting up is when I did a couple 5000 rpm 1-2 shifts, and the last one (obviously) is what caused the master cylinder to lock.
I spoke with Andy today and he thinks he knows what happened...the coupler from master to the slave cylinder may have broke or came apart. Now, I just wonder why this happened and if I replace the master cylinder will this happen again.
There are several links in the CF forum about upgrading the clutch master cylinder and slave cylinder. The factory slave cylinder has smaller passages (fluid) to help relieve drive train stress.
The after market ones remove these bottlenecks and allow the fluid to flow unrestricted. This is esential with aftermarket performance clutches.
Additionally, the aftermarket clutches release higher, (not on the floor) and some of these clutches need floor stops so that you don't press the clutch in to far.
Your problem is relatively easy to remedy. Pick up an adjustable master cylinder assembly from cartek or mcleod. get a RAM clutch slave and an LAPD clutch bleeder extention.
I would talk to Andy and see what type of slave system, etc that was installed on your vette before proceeding. Most of all I would take the vette out of dealer and find a local tuner to the make repairs as the dealer is not familiar with these items.
The clucth master cyclinder is easy to remove, just remove the rod form the pedal inside, go out to the firewall, twist it and it will come right out.
Talking to Andy, he hasn't had very many stock master cylinders fail on customers, and he has installed plenty of aftermarket clutches. Also, Textralia claims that the stock master should work.
In addition, I am not going to start putting all of these aftermarket parts in my car. I'm gettting tired of wrenching on the thing. Right now I just want a nice fun car to drive.
If I'm going to have a factory master clyinder put in, did they upgrade them after '01? I thought I read that somewhere.
http://vetteweb.com/tech/vemp_0506_clutch/index.html
If you didn't want to wrench why did you go and change everything around and put a manual in it?
It takes time and patience to work out the kinks.
You used an aftermarket clutch and did not upgarde the affected components which is what caused your failure.
It doesn't cost but a few extra bucks to buy the improved components which would have been a wise investment given your current situation. If you want throw good money after bad that's your call.
I was just trying to point you in the right direction. You should do a search on CF of clutch problems.
Good Luck.
Good Luck.
Thanks ajg1915,
I have since taken your advice and sent my car to Orange County Corvettes (top notch guys and excellent service
Hopefully this will take care of the problems and I won't be second guessing things. I have learned my lesson and will only used brand new parts from now on.
I've had a few of my own short-cuts come back at me and bite me in the a$$, hence I have now started doing research prior to jumping into any more mods.
Tony
