telescopic steering wheel fuse?
Old May 20, 2006 | 11:20 AM
catfish2's Avatar
catfish2
Default telescopic steering wheel fuse?
My driver side sport seat will not operate in any way. The tele wheel also quit at the same time. I have the fuse diagram with the seat numbers but see nothing about the tele wheel. Is it on the same circuit? Also, should I be looking another direction other than the fuses?
Old May 20, 2006 | 12:08 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If you have memory package it is on the same circuit as drivers side.
(That is Telescope wheel & Drivers seat).
Old May 20, 2006 | 01:28 PM
catfish2's Avatar
catfish2
Yes, I have memory pkg. Is there a fuse or breaker. I see a Driver Seat Control Module fuse and a Driver Power Seat circuit breaker on the schematic. I assume it(memory pkg.) will be one of those?????
Old May 20, 2006 | 02:55 PM
Casem1's Avatar
Casem1
There are error codes for the seat control module. Check the error codes in the DIC to see what comes up. That should give you the best idea of what may be happening. I get a code for the scm quite often but I just click the telescoping switch a few times and all works well again.
To telescopic steering wheel fuse?
