500$ to spend
Old May 20, 2006 | 07:40 PM
dwarmenzerk's Avatar
dwarmenzerk
Default 500$ to spend
two options I have.
1. buy a cam. lg G5X3 cam and an tranny cooler
2. buy an slp blackwing intake, new spark plugs (plat. 4's), plug wires (high performance), and tranny cooler.
eithor way i need a tranny cooler stupid stuff running too damn hot for my taste.
I have a 99 a4 coupe. What will be the best bet for me to do.
Thanks guys in advance
~Joe
Old May 20, 2006 | 07:43 PM
NSTG8R's Avatar
NSTG8R
well with a cam you're going to need more than 500 will buy you.
either save your $ or go with option 2
Old May 20, 2006 | 07:46 PM
wannabe-psi's Avatar
wannabe-psi
----snake bitten----
option 2
Old May 20, 2006 | 08:13 PM
dwarmenzerk
well actually i have found a G5X3 cam brand new for less than 500$. So just not sure which route to take..
Old May 20, 2006 | 08:48 PM
tiojames's Avatar
tiojames
Default Cam
To install the cam you will need new springs, pushrods and gaskets- another $300-400. Go with option 2.
Old May 20, 2006 | 08:50 PM
mitchcole's Avatar
mitchcole
Option 1. if it takes more $$ then shell it out. Option 2 won't make any difference except make your wallet lighter.
Old May 20, 2006 | 09:01 PM
NSTG8R's Avatar
NSTG8R
.. ok .. buy the cam.
install it. enjoy. in fact go with the G5X5 ..
... everybody knows better.
Old May 20, 2006 | 09:13 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Plus tuning..$550.00
Forget plat plugs, go with TR55s..better performance and get a hurst shifter.
Old May 20, 2006 | 09:32 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
500 dollars will buy you a tune.....you are now out of money and have not added anything... You just cant throw a cam in the car ...the tune is needed to make the car take advantage of the new cam profile...
any real cam will require new springs, gaskets, push rods, and a tune...
any thoughts of a cam is about a 1500 dollar investment..
Old May 20, 2006 | 10:51 PM
MY1STPEWTER's Avatar
MY1STPEWTER
And the 1500 would probably be on the low end of the scale. Lg's cam kit, which would be the G5X3 (in your case) springs, push rods, etc. is $1400. Then if you don't have the know how to install would be another 400 to 600 or more and then the tune for 500. I spoke with them the other day and their cam kit installed with a tune is 2,400. There are some cam kits you can get for 700 or so, but as you can see that's just the start of it.
Old May 21, 2006 | 09:52 PM
D_BlueVette's Avatar
D_BlueVette
But Texas Speed has a cam kit that would cost a fraction of what was quoted above even intalled, so shop around.
Old May 21, 2006 | 10:18 PM
Mitch.Shea's Avatar
Mitch.Shea
what mods do you have? i would save some more money and buy headers... cam you will need springs ext... and a tune so your looking at 1,200-1,500
Old May 22, 2006 | 01:38 PM
mdhmi's Avatar
mdhmi
I had solid gains with a Blackwing intake.
Mark
Old May 22, 2006 | 02:16 PM
Billdog350's Avatar
Billdog350
Option 3: K&N with zip tie mod, used catback exhaust off the forum, and tranny cooler.
K&N with zip tie will flow very similar to the blackwing for a fraction of the cost. A used catback will add ~20rwhp with the new air filter setup.
Plugs and wires won't gain you anything unless your existing ones are worn out.
Tranny cooler will definitely help.
Start saving ~$1000 for a cam OR Headers...but keep in mind they need to be done together for optimal gains (~70rwhp).
Old May 22, 2006 | 03:55 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Option #2 is the way to go right now.
Old May 22, 2006 | 04:08 PM
REDEVIL's Avatar
REDEVIL
Save it for repairs you'll have in the future.
Old May 22, 2006 | 09:52 PM
Dr Chill's Avatar
Dr Chill
How about an hour in the champagne room at Rachels or Solid Gold?
Old May 22, 2006 | 10:59 PM
NSTG8R's Avatar
NSTG8R
.. yeh .. OOOOK .. i swear .. i'd love to know where you got these numbers from.
Old May 26, 2006 | 02:29 PM
Yell-01Vette's Avatar
Yell-01Vette
I think Dr. Chill has posted the best suggestion, but I'm going with a Callaway Honker for my $500, I have a buddy that is a tuner.
To 500$ to spend
