How do you unlock the steering?
Old Aug 25, 2001 | 05:06 AM
copterjohn's Avatar
copterjohn
3rd Gear
Default How do you unlock the steering?
Well its happened again. The steering on my 98 has locked up and this time I can't unlock it. This has happened before and all I had to do was disconnect the battery, but this time that wont do the trick. Is there any other way to unlock it? Any advice would be appreciated. Also should I look forward to this on my 01 z06?
COPTERJOHN :cry
Old Aug 25, 2001 | 07:59 AM
Dr_Tony's Avatar
Dr_Tony
Default Re: How do you unlock the steering? (copterjohn)
Some have suggested:
1) Pull fuse 29 from under hood
2) Erase all DiC codes from computer.
Let us know what happens. :jester
Old Aug 25, 2001 | 09:45 AM
levrac68's Avatar
levrac68
Default Re: How do you unlock the steering? (Dr_Tony)
Tony, I thought you were totally mechanically illiterate. :rolleyes:
Old Aug 25, 2001 | 01:01 PM
UR2SLW's Avatar
UR2SLW
Also turn the steering wheel with some force to the left and/or right while turning the key to start the car. Best of luck to you. Other option is to order the Column Lock Bypass. I put on mine about two weeks ago no problems since.
Old Aug 25, 2001 | 07:57 PM
copterjohn's Avatar
copterjohn
3rd Gear
Tony,
Thanks for the tip. Pulling fuse 29 did the trick. Now I dont have to deal with some yahoo flat bed driver who would most likely tear my front end to heck.
Do you think I should take it to the dealer or just get the bypass kit and forget about it? Oh yeah, where can I get the bypass kit? Thanks again!
COPTERJOHN :D
To How do you unlock the steering?
