Mich. Remove Bump Strips
Old May 21, 2006 | 11:16 AM
Corvector's Avatar
Corvector
Default Mich. Remove Bump Strips
Any luck removing the side "bump strips" from the sides of the car - without leaving a blemish on the paint underneath?
Old May 21, 2006 | 11:22 AM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Yes it's fairly easy. There are a few different methods. Do a search under BSM removal. (Body Side Mouldings) You will find all kinds of information.
Old May 21, 2006 | 12:02 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
check this link out
http://www.corvetteflorida.com/forum...hread.php?t=40
Good Luck
Old May 22, 2006 | 07:52 PM
Corvector's Avatar
Corvector
Default Fishing Line Trick
Thanks for the replies. The fishing line trick sounds pretty easy. All I have to worry about is the "somewaht darker paint" under where the strip was. That wouldn't look too good. Probably more likely on older cars. Thanks again!
To Mich. Remove Bump Strips
