Red Line ATF question........again.
Old Aug 25, 2001 | 12:13 PM
99 to 2000's Avatar
99 to 2000
Default Red Line ATF question........again.
Can anyone confirm that the Red Line D4 ATF is the right fluid to put in my 6 speed? They have a few others but I think that this is the right one.
Also, I haven't been able to find a pump to pump the fluid up into the fill hole. I heard that there is a simple pump that attaches to the quart bottles but I haven't been able to find one. Any ideas??
Lastly. Where is the best place to buy Red Line products?
Thanks for your help. Dick A.
Old Aug 25, 2001 | 12:18 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Red Line ATF question........again. (99 to 2000)
Yes that is the correct one. D4ATF for your six speed. Youll want 5 quarts, but will like only get just under 4 back in.
Make sure car is level.
You can get the pumps at places like Pep Boys, Autozone, Oreilly etc...
go to http://www.redlineoil.com to search for a dealer near you, or you can order it. I beleive LAPD (forum vendor here) sells it too.
Old Aug 25, 2001 | 01:46 PM
wstory1's Avatar
wstory1
Default Re: Red Line ATF question........again. (kewlbrz)
kewlbrs is correct. Good luck with the changeover.
To Red Line ATF question........again.
