help, what do i do!?!?
Old May 22, 2006 | 07:53 AM
comfortracing's Avatar
comfortracing
Default help, what do i do!?!?
i was putting a bassani x-pipe and bulllet exhaust on. i pb blastered the heck out of the collector bolts, but two of them snapped off with little or no effort
they look like they are studs and can be replaced...they have like a sort of bolt head on them. my question is #1 is this true #2 are they reverse thead #3 any suggestions on getting these little @#$%'s out?
where can i get these from...is this one of those chevy parts where i have to buy the whole manifold to get them!?!?
thanks in advance,
chad
Old May 22, 2006 | 08:05 AM
c5chines's Avatar
c5chines
Default Bolts
Heat is the answer.Oxy/acetylene torch and heat the bolt/stud to cherry red and it should turn right out. get the correct replacement from the dealer.Chuck.
Old May 22, 2006 | 02:05 PM
comfortracing
so is it reverse threads? i'd hate to be turning it the wrong way?
Old May 22, 2006 | 02:34 PM
c5chines's Avatar
c5chines
Default stuck
All standard threads,righty tighty, lefty loosy!!! Just really stuck together.Chuck
Old May 22, 2006 | 03:34 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
They will come out and as mentioned, you can get the OEM replacement from the dealership or ECKLERS varily cheap.
Micah
Old May 22, 2006 | 03:49 PM
comfortracing
ok, thanks! i was kind of hoping i didnt have to heat them up, but i can go buy a torch if need be.
To help, what do i do!?!?
