harmonic balancer costs???
Old May 22, 2006 | 11:03 AM
Sully1882's Avatar
Sully1882
Default harmonic balancer costs???
How much should I expect for parts and labor when replacing the harmonic balancer? I have noticed mine is wobbling and causing some small chirps which go away after drving but i am just concerned that if not fixed it could cause some damage to something else. Should there be a hurry in replacing this and what could it cost?
Thanks,
Thomas
Old May 22, 2006 | 11:20 AM
corvettebob1's Avatar
corvettebob1
Thanks,
Thomas
Do not drive your car until you replace the balancer!
I can't comment on the cost since I did my own, but it will require removing the steering rack.
A loose or failed balancer will cause the crankshaft to fail in short order!
BTW pin the new balancer to the crankshaft, the current one is a press fit that sucks.
