shimming and porting oil pump
Old May 22, 2006 | 05:16 PM
SFengineer's Avatar
SFengineer
Default shimming and porting oil pump
Does anyone know a link for how to port and shim an LS1 oil pump? I hear people talking about this all the time, but never seen instructions for how to do it. Please help!
Old May 22, 2006 | 05:41 PM
Phil97SVT's Avatar
Phil97SVT
You drop the plug and add a .100 spacer.
Old May 22, 2006 | 08:39 PM
RED99's Avatar
RED99
Old May 22, 2006 | 09:01 PM
PrayN4C5's Avatar
PrayN4C5
You have a PM SFengineer, i need your help
Old May 23, 2006 | 03:31 PM
SFVetteman's Avatar
SFVetteman
Frankly, with the availabillity of the Melling oil pump for LS motors, I wouldn't bother. The Melling pump offers 15% more volume and 10 PSI more pressure right out of the box compared to a stock pump. If that's not enough then you can have it ported.
Old May 23, 2006 | 07:14 PM
RED99's Avatar
RED99
I'm putting in a LS4 pump which is suppose to have 30% more volume of flow. But if there is any other tricks, then why not why I have it on the bench.
What is it that they are porting? Where the pick up tube goes in? And I don't understand the shim? A .100"
Old May 23, 2006 | 08:56 PM
MikeV's Avatar
MikeV
The shim just adds spring preload to the relief to raise the oil pressure...
Mike V
Old May 23, 2006 | 09:31 PM
RED99's Avatar
RED99
Then do people shim the Z06 pumps, or just the LS1's pumps! The reason I asked is because I read somewhere that the only difference between the LS1 and the LS6 pumps is the pressure relief spring.
Old May 23, 2006 | 09:41 PM
SFVetteman's Avatar
SFVetteman
Since the LS6 came out there is only one part number for the pump: 12563964. The older LS1 pumps gave some people problems and were discontinued.
Old May 23, 2006 | 11:37 PM
Shane_S's Avatar
Shane_S
I bought an LS6 pump already ported from LG Motorsports. Think it was $180 or something like that.
Shane
To shimming and porting oil pump
