How do you "clear" the DIC?
Old Aug 25, 2001 | 02:52 PM
hal26's Avatar
hal26
Default How do you "clear" the DIC?
Thanx in advance! :D
Old Aug 25, 2001 | 03:01 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: How do you "clear" the DIC? (hal26)
If you mean, how do you clear Diag codes:
turn key to on position or run.
clear any messages, like door ajar etc...
press and hold options while pressing fuel 4 times.
When in manual mode, you can press and hold reset for each code.
cant remember offhand which buttons scroll up and down through codes when in manual mode.
pressing E/M will exit you out of diag mode.
Old Aug 25, 2001 | 03:06 PM
hal26's Avatar
hal26
Default Re: How do you "clear" the DIC? (kewlbrz)
Is this one of the temporary fixes if you are stuck somewhere with the CLB prob? :confused:
Old Aug 25, 2001 | 07:02 PM
ataDude's Avatar
ataDude
hal26 - clearing the code on the column lock problem when it occurs won't help a bit. Too late then - it's a mechanical problem. :bb
Spend the $60 for the CLB and 30 minutes install time so you won't have to worry about when it will happen. :D
Old Aug 26, 2001 | 11:18 AM
Ram Air Tony's Avatar
Ram Air Tony
Default Re: How do you "clear" the DIC? (ataDude)
go to the doctor and get some antibiotics :lol: :yesnod:
just kiddin :D
Old Aug 26, 2001 | 03:18 PM
JohnGlenn's Avatar
JohnGlenn
Yeah I hear it comes in a cream :D :D
To How do you "clear" the DIC?
