LS6 G Code on ignition coil
Old May 23, 2006 | 06:48 PM
Blue Lightening's Avatar
Blue Lightening
Default LS6 G Code on ignition coil
My kid had a brand new LS6 engine put in his Trans Am. The car started running poorly and is missing. Auto Zone did a scan and are saying that the problem is an igniton coil with a G Code. Does anyone know what cylinder this is?
Old May 23, 2006 | 08:07 PM
dpd's Avatar
dpd
never heard such a thing.what you have is a "p" code which has the "p" stands for powetrain. anyway for a mismife.you get "300" codes.p300 is "random misfires",p301 is misfire on cylinder #1,p302 is misfire on cyl. #2,and so on.could it be a coil problem?possible,but it sounds like the guy at auto zone didn't know what he was reading/looking at.you need to know the full code to know what hole misfiring.pull the plugs.the one that looks the oddest [all black,all white,broken,bridged]probably the cylinder with the dead hole.jmo
Old May 23, 2006 | 10:42 PM
Blue Lightening
Thanks, I went back to my son for clarification. Here is additional info he gave me. We are trying to figure out which coil G is. This is on a brand new LS6 engine that was stuck in a Trans Am
P0357, Ignition coil G, Primary and Secondary
Old May 24, 2006 | 04:37 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
P0357 is for the number 7 ignition coil according to GM VIS.
Old May 24, 2006 | 08:06 PM
fdxpilot's Avatar
fdxpilot
Makes sense.
ABCDEFGH
12345678
Old May 24, 2006 | 09:29 PM
John@SDPC's Avatar
0John@SDPC
Former Vendor
Here is some detailed diagnostic information for that DTC. HTH
Old May 24, 2006 | 10:48 PM
Blue Lightening
Thanks for the info...The plot thickens...Number 7 wasn't firing. Replaced the plug, spark plug wire and voltage pack...Still miss fires...we are thinking there is a broken wire in the harness????
The car was running fine. Had a new clutch put in it and it misfired ever since.
To LS6 G Code on ignition coil
